Projects Inflatable paint booths
Discussion in 'The Hokey Ass Message Board' started by plymouthgoat62, Feb 18, 2024.
  1. plymouthgoat62
    plymouthgoat62
    Anybody on here use any of the inflatable paint booths that you can get at Eastwood or Amazon? Looked at a couple different ones online. Just wondering if anybody's used one and if they live up to they hype. Thanks.
  2. GordonC
    GordonC
    My buddy and I used one he bought second hand. It was in good shape and had the blowers with it. We painted his 1965 Dodge Dart with it. The paint job, for an amateur, came out pretty good. He had never painted before and I was guiding him. Some of the issues were how warm it got inside, the blowers needed to be elevated so as not to **** in debris (something he learned after the fact), and lighting, which more of would have helped. Would we do it again? Absolutely, and we will for a car I am doing. His booth had a changing room on one end which helped with setup/reload without having to open the whole front of the booth to do it. The pictures below are after shooting it. We still had to cut and buff it and once that was done it looked even better. If I can find a pic of it from then I will post it up.
  3. plymouthgoat62
    plymouthgoat62
    Thanks @GordonC. This is exactly what I was looking for, someone who had success with it. The paint job looks great. I'll be ordering one as soon as the snow is gone here in Wisconsin. I'll be painting my avatar in it! That's my 53 Chieftain that I have to do some sheet metal work to and then paint.
  4. GordonC
    GordonC
    Here is one from after cutting and buffing. Best I have of it for now.
  5. GordonC
    GordonC
    Your welcome. Prep is the key. Clean working conditions and follow all instructions from the paint mfgrs. Good compressor and line filters and you will get a decent job. Remember if anything screws up it can be sanded out and resprayed if need be.
    plymouthgoat62 likes this.
  6. plymouthgoat62
    plymouthgoat62
    Wow. I can definitely see how everything reflecting on it is much sharper in the paint. Post some pics of it going back together as well. Paint looks dust free. You must have put some wood down in the booth and rolled it in?
    gimpyshotrods likes this.
  7. plymouthgoat62
    plymouthgoat62
    Good advice. Thanks.
  8. GordonC
    GordonC
    If I recall we had 2 4 x 8 sheets of 1/2" plywood that were on the ground and we set the booth up over them. Just rolled the rotisserie down the ramp at the front of the garage and into the booth. Easy enough to do. I remember my buddy looking at the paint job going it doesn't look very good and I told him now the hard work begins as the paint has to set up for a while and then the whole car had to be wet sanded and buffed out. Since he has done that he is much happier with it! 1953 Chieftain rag top. Can't be many of those around. That should be nice once you get it squared away.
  9. hotrodA
    hotrodA
    Wow! That looks great!
    Any more details? Paint? Reducer? Spray gun?
    plymouthgoat62 and GordonC like this.
  10. BJR
    BJR
    I have had an inflatable before, but it wasn't a paint booth! :eek: :p
  11. gimpyshotrods
    gimpyshotrods
    A clean room is a clean room!
    Top dollar installed booth, or inflatable, all of the same rules apply.
  12. Phil P
    Phil P
    Check out this utube video.
    Phil
    Squablow, GordonC and alanp561 like this.
  13. oldiron 440
    oldiron 440
    I’ve watched a video where they made a system for supporting the booth with the fans off. It seems like that would be a good idea just watching this video but just being able to leave a newly painted part overnight before moving is sometimes necessary if not convenient. I also saw the inflated booth was not water proof under a light rain.
    Squablow, plymouthgoat62 and GordonC like this.
  14. GordonC
    GordonC
    hotrodA I don't recall the specifics on the paint and gun used but I sent a txt to my buddy to ask him. I'll post up his answer when I get it.
    hotrodA likes this.
  15. plymouthgoat62
    plymouthgoat62
    Thanks. Watched the video. Just what I'm gonna do too.
  16. Roothawg
    Roothawg
  17. Bandit Billy
    Bandit Billy
    I got mine from Vevor. Chinesium. But it worked.
    Blew it up in my back courtyard, told the neighbors we were hosting a kids birthday party.
    Goes up in a minute.
    It has a paint mixing room on the end, window sides and skylights. those are filters at the end for air flow.
    I purchased an explosion proof exhaust fan to help vacate the fumes and overspray. I ran it through a box of furnace filters that I rather crudely just cut a hole in the back of the box and stuffed the hose in.
    Hey, it worked. I did have to buy my wife a new box of filters for the house.
    Lot's of space inside, and good lighting.
    The only issue is the sun. You can see from the pictures, I chose an overcast day, and it was 70-75 in the booth. The sun peeked out from behind a cloud, and the booth became 90-95 in seconds, wrong reducer, clear flashing too fast, solvent pops, re-painting parts. PITA!
    I like the booth, I will use it again. but I will set it up indoors or under the trees in the yard next time. Lesson learned.
    It yielded this, in my back yard, exactly where it sits...and "damn it Jim, I'm a mortgage banker, not a car painter"!
    Total cost of the booth and explosion proof fan and hose = right around a grand delivered.
    Somethings to keep you up at night.
    1. If you live in an area where rolling blackouts occur, this thing would collapse on your wet clear coat, without notice!
    2. Make sure your GFI outlets will hold the fans... or see above bullet point.
    3. It is a giant plastic greenhouse; the sun can destroy your efforts in seconds!
    I'm glad to rent mine out if you're local.
    rockable, saltflats, GordonC and 5 others like this.
  18. continentaljohn
    continentaljohn
    We use one at work spraying finish coats on the boats and it’s pretty good only drawback is needs more light .
    saltflats likes this.
  19. evintho
    evintho
    Ok.....had to post this. It's not an inflatable booth but it is portable. It's also not mine but it is pretty cool!
    Shitbox, gnichols, X-cpe and 5 others like this.
  20. 05snopro440
    05snopro440
    On one forum, a guy made a PVC frame to hold the booth up with the fan off.
    Bandit Billy likes this.
  21. Bandit Billy
    Bandit Billy
    Thats a good move!!
    GordonC likes this.
  22. 8E45E
    8E45E
    Did you hose the plywood floor, and getting it wet as is done on concrete in a permanent paint booth?
  23. 05snopro440
    05snopro440
    He said they put the booth over the plywood. The booth has its own floor.
  24. GordonC
    GordonC
    The guy that sold the booth to my buddy had made up a pvc framework that he gave us with it but he used it to hang extra lighting on. Could be used for both I suspect. My buddy used all PPG products and a not too expensive Finishline spray gun.
  25. plymouthgoat62
    plymouthgoat62
    Very nice.
  26. plymouthgoat62
    plymouthgoat62
    Too far away to rent. Wisconsin!
  27. plymouthgoat62
    plymouthgoat62
  28. GordonC
    GordonC
    Thought I would post up some more current shots of my buddy's backyard restoration on his 1965 Dodge Dart.
    20240613_124236.jpg 20240613_124249.jpg 20240613_124307.jpg 20240613_124318.jpg 20240613_162100.jpg 20240613_171342.jpg
    rockable, SS327, Phillips and 2 others like this.
  29. gnichols
    gnichols
    from Tampa, FL
