Piekiller, you need to get with the inliners or stovebolt groups. Lots of info there. Do a Google search.
I couldnt find any info- you might try inliners.org here is a spec from the crane site- 194-250 C.I. Camshaft Specification Card BACK TO LIST Part Number: 200511 Grind Number: H-192/2667-2S-12 Engine Identification: Start Yr. End Yr. Make Cyl Description 1962 1984 CHEVROLET 6 SMOOTH IDLE, DAILY USAGE, FUEL ECONOMY, 1600-2200 CRUISE RPM, 7.75 TO 8.75 COMPRESSION RATIO ADVISED. BASIC RPM 1000-4000 Engine Size Configuration 194-250 C.I. Valve Setting: Intake .000 Exhaust .000 HOT Lift: Intake @Cam 2667 @Valve 467 All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 2847 @Valve 498 Rocker Arm Ratio 1.75 Cam Timing: TAPPET @.004 Lift: Opens Closes ADV Duration Intake 13 BTDC 55 ABDC 248 ° Exhaust 63 BBDC 17 ATDC 260 ° Spring Requirements: Triple Dual Outer Inner Part Number 99838 Loads Closed 110 LBS @ 1.688 or 1 11/16 Open 320 LBS @ 1.208 Recommended RPM range with matching components Minimum RPM 1000 Maximum RPM 3500 Valve Float 6500 Cam Timing: TAPPET @.050 Lift: Opens Closes Max Lift Duration Intake (11) ATDC 23 ABDC 107 192 ° Exhaust 39 BBDC (15) BTDC 117 204 ° Remarks:
