Technical Info on Flathead Head Acorn Nut Covers?
Discussion in 'Traditional Hot Rods' started by painterdaveee, Mar 5, 2014.
  1. cs39ford
    cs39ford
    Best way to install them
  2. 421-6Speed
    421-6Speed
    I also put them on when the paint is wet and if they fit a bit loose just give them a rap on one flat to distort just enough for a tight fit. Then if you need to remove use a 3/4 end wrench rattle it back and forth a few times and they pull right off.
  3. 97
    97
    Send the metric Chinese junk back to the supplier and tell them to get you something Made in America that fits.
    The Shift Wizard likes this.
  4. 1pickup
    1pickup
    @HOTRODPRIMER Just wondering how that tape is holding up after 4 more years...
    Hollywood-East likes this.
  5. 55styleliner
    55styleliner
    I just gave mine a little squeeze with a pair of pliers. That was more than enough to tighten them up enough they had to be tapped on with a soft hammer.
  6. sloppy jalopies
    sloppy jalopies
    buddy went all stainless/ shiny fasteners on his flattie, hardware store had small acorn nuts, pretty good quality, so he asked and because he wanted 50 they ordered them from their distributer... took a little while...
  7. Bandit Billy
    Bandit Billy
    I've seen it happen. :rolleyes:
  8. Get some of them 2" long chrome spike nuts the motorcycle guys use.
    Of course it'll make your flattie look like a prehistoric porcupine, but whatever. :confused:
    alanp561 and pat59 like this.
  9. J2X
    J2X
    A short piece of black plastic electrical tape INSIDE the cover - Easy on and easy off and no clean up
