Info/Pics 1948 to 1952 Ford F1 Trucks
Discussion in 'The Hokey Ass Message Board' started by 50chevy, Jul 6, 2006.
  1. stragedy
    stragedy
    The S10 is a bit wide at the front of the frame, but that can be worked out.
    I've got mine on an Explorer frame and it works well because of the narrower frame, torsion bar suspension and a couple of other things.
  2. rpol7966
    rpol7966
    Here are some shots of my '50. I picked it up in Tucson in January. It's still got the flathead V8 and three speed transmission. I intend to to put a T5 transmission and eventually a Jag IFS. The Jag IFS is really simple swap in the '48-'52 trucks.
  3. bobj49f2
    bobj49f2
    I would personally look into the Jag front clip. Go over to the Ford Truck Enthusiasts' site, http://www.ford-trucks.com/forums/forum41/. There's a lot of talk about the Jag. The best thing to do is do a Google search of the site for both "jag ifs" and "frame swap". Frame swaps get a lot of heat over there but there is a lot of good info.
  4. henrys_way
    henrys_way
    from Maine
    [​IMG]Does anyone know where to get the best re-pro running boards? I want to get a pair that are really good. I hear ROCK VALLEY are nice. Any input would be helpfull....heres the truck....just lowered her 3 inches via dropped axle.....
  5. limp
    limp
    i ordered a set from old car center in bc. they have not showed up yet and i can't wait to see them. I beleive they are denis carpenters boards. The price seems a little hard to swallow at first but i could not find a set that weren't beat to ****.
    mike
  6. Price the steering rack before you go with this option, its lots of $$$$$$$$$$ to replace
  7. Dirk35
    Dirk35
    Do the 51 type front fenders bolt on to the cab basically the same as the 48 type? Reason I ask is I am building a 48 for my daughter and want to ditch the horizontal bar grill for the toothy grin of the 51 type.
    I ***ume I need the complete front clip as I know the thing the grill and headlights bolt to are totally different along with the lower parts of the front fenders. I also like the 51 hood louvers better.
  8. You are correct. Totally different front clip, but will bolt on your early truck.
    Whats the matter you don't like the monkey face?
  9. Dirk35
    Dirk35
    I dont, but I cannot put my finger on why I dont like it.
    Know where I can get the new clip around Oklahoma?
  10. No I don't. I haven't been to OK in about ten years, but last time I was there to visit family in Dill city there was a 51-52 abandoned down a dirt road off a dirt road just outside of town, that I saw. The dirt was red if that helps:) ROFLMAO
  11. stoneman
    stoneman
    454 t400
  12. charleyw
    charleyw
    Stoneman,
    Got a shot of how the hood pins work with the Hood? I'm considering something similar for my '50. Nice project.
    Thanks
  13. goon56
    goon56
    from new jersey
    my buddies- 351 modified and a 5 inch drop axle. fun truck
  14. goon56
    goon56
    from new jersey
    spotted this at the jalopy showdown two years ago. real cool ride
    exterminator likes this.
  15. stoneman
    stoneman
    here's a few more
  16. charleyw
    charleyw
    Thanks,
    Do you access the pins through the front hood opening?
  17. stoneman
    stoneman
    Yes, it's a little bit of a h***le but it's works, and secure.
  18. SquashThatFly
    SquashThatFly
    Id really like to get some more info on this truck. Specifically the suspension and frame. It sits absolutely perfect
  19. flynstone
    flynstone
    here are a few
  20. Deadanimal
    Deadanimal
    from AZ
    Hey All,
    I have a 52 F1 pretty much stock on the suspension and I'm wondering if you think I will have a hard time fitting 20'' X 9.5'' rims on it. I came across an awesome deal and I think the rims look awesome. i have measured the back spacing and it's bout 4.5"".
    From all the measurements I have taken I think they will fit with the right size tires. Any thoughts?
  21. mano
    mano
    Here is my 52.
  22. 51PanelMan
    51PanelMan
    A Panel is a truck, right?
    Here are two of mine. Both are stock. The 51 has a V8 flathead. The 52 has the OHV 6 cyl.
  23. 48 being converted to a 51-52 front clip...
  24. fordtoughwithchevystuff
    ...here is my 52 f2 [​IMG]on a chevy half ton frame...
    sko_ford likes this.
  25. 48merc
    48merc
    from BC, Canada
    Here is a picture of my 48 merc
  26. gsharp
    gsharp
    from Ohio
    Interesting thread, as I'm about to begin work on a '52 F3...going for a g***er vibe. The flathead went to a deuce project, and the rest of the driveline went to another F3. Besides converting the 8-lug front hubs, I want to shorten the bed and rear of the frame. Not sure if an F1 bed would fit, as I know the dimensions are different from the F3 beds. Any of you tried an F1 bed on an F3?
  27. bobj49f2
    bobj49f2
  28. gsharp
    gsharp
    from Ohio
    Thanks for the info, I'll check it out!
  29. AHotRod
    AHotRod
    Anymore out there?
  30. RAF
    RAF
    from MA.
    Here's my 51 F-1, going through the brakes and wiring now hope to have it on the road by the end of the month.
