Information on a Renault Four Speed Transmission
Discussion in 'Off Topic Hot Rods & Customs' started by OleADTruck, Dec 6, 2025 at 7:00 PM.
  1. OleADTruck
    OleADTruck
    I have a four-speed transmission I picked up a few years ago. I am trying to find some information on it if possible. It is made by Renault in Argentina. It was used in a D cl*** drag car years ago. It has a custom bellhousing and adapter plate that allow it to bolt up to a Chevrolet V8. It has a Chevrolet 10 spline input shaft, and the output shaft uses a T10 yoke. The shifter is a nice tight design but there are no identifying markings. When installed it is the same length as a Muncie four-speed. It has a plate that was originally riveted to the transmission, but it is largely illegible from wear. It has a flywheel that bolts up to the Chevy crankshaft. The pics show the markings on the flywheel. I still need to get photos of the Bellhousing and adapter plate. I had it in my 55 Chevrolet Series 1 truck, but the shifter was too short to comfortably use, and I didn't want to alter the shifter as I don't have a clue where to get replacement parts. Has anyone ever heard of this transmission and have any information.
    4 speed B.jpg 4 speed A.jpg Flywheel A.jpg Flywheel B.jpg 4 speed C.jpg Flywheel C.jpg
    34 GAZ likes this.
  2. Ned Ludd
    Ned Ludd
    The history of the motor industry in South America contains some unexpected mergers and takeovers. As a result, things often got badged in ways which more or less obscured their design origins, like the Brazilian VW 1500/1800 of c.1982, which was basically a Hillman Avenger with Volkswagen badges.
    A quick Wikipedia dive reveals that Renault of Argentina has roots in Industrias Kaiser Argentina (IKA). The Rambler-based IKA-Renault Torino appeared in 1966 and used a ZF 4-speed manufactured under licence. I suspect that that is what you've got.
    I suspect that the design might have been unique to the Torino. I don't really have the time to verify that.
    RodStRace and 34 GAZ like this.
  3. Last edited: Dec 8, 2025 at 5:22 AM
    RodStRace and Ned Ludd like this.
  4. RodStRace
    RodStRace
    @OleADTruck first post, welcome to the HAMB!
    When I read you post, I was shaking my head. What an offbeat, out of left field query!
    And then 2 of the members who know the wild stuff come riding in!
    @34 GAZ that car is sharp!
