Hot Rods Information
Discussion in 'The Hokey Ass Message Board' started by Joe Twitchell, May 7, 2015.
  1. Joe Twitchell
    Joe Twitchell
    What is the main difference between a 2 piece rear main seal and a 1 piece, chevy 350 are the oil pans the same ?
  2. oil pans are not the same , and the flywheel/flexplate are different too
    going to one piece seal the crankshaft basically lost a counterweight , so one was added to the flexplate/flywheel. the bolt pattern on the crankshaft flange is different so you can not mix them up
    Joe Twitchell likes this.
  3. fms427
    fms427
    About everything is different -not a "retrofit" thing-engine is either 1or 2 piece seal. Crank,block,flywheel,pan,etc. is different.....
  4. it should be mentioned that any transmission that will bolt to a 2-piece seal SBC will bolt up to a one piece seal SBC....the bolt pattern there is the same. you just have to use the correct flexplate/flywheel
  5. Joe Twitchell
    Joe Twitchell
    Thanks for the help
