Art & Inspiration Infrared Thermal Photographs
Discussion in 'The Hokey Ass Message Board' started by Skankin' Rat Fink, Apr 10, 2014.
  1. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Well hey, everyone.
    I took home a thermal imaging camera from work today, for some authorized practice time. Of course after I finished the serious stuff ... my mind turned to the car. Flatheads love to get hot!
    Here's an infrared ("predator vision") picture I took of my engine, followed by the standard visible-light photo.
    I know HAMBers come from all sorts of different occupations ... anyone else take any photos like these?
    302GMC likes this.
  2. themoose
    themoose
    Wow...That's pretty cool...errrr or should I say hot..Oh whatever it is I like it.
  3. autobilly
    autobilly
    That intake manifold and fuel feed pipe are pretty hot.
  4. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    The exhaust manifold is the one on top, actually. And the small line running upwards is the heat pipe for the choke.
  5. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Better view of the intake and exhaust
  6. autobilly
    autobilly
    Makes sense, thanks for posting.
  7. The impressive thing is to do something like that in a windowless garage. When you turn off the lights the infrared image is still there because it is looking at heat and not light. The first time I saw an IR system it was in a laboratory without windows. My thought was that if my TV looked that bad I would call a repairman, then someone switched off the lights and the image was still there.
    Charlie Stephens
  8. EBW
    EBW
    I use TIC's at work and they are a great tool. That is awesome using it on the engine, never thought to use it on that.
  9. stainlesssteelrat
    stainlesssteelrat
    from ms
  10. Cooon
    Cooon
    Not really the same kinda photo, but these were taken at night, with camera on long timing shot, and a red laser flashed at the car back and forth while taking photo
    Yeah prob not the same really.
  11. gnichols
    gnichols
    from Tampa, FL
    Neat. Reminds me of my photo recon days in the Army, when you could pick out that lone idiot who just HAD to have a smoke out in the forest on a moon-less night - giving his whole unit's position away! Don't the dyno tuners use these kind of tools, too? Gary
  12. LOST ANGEL
    LOST ANGEL
    This view really shows how the heat deflector under the carb makes a big difference in the temp of the carb! Great shot.-MIKE:cool:
  13. 57 HEAP
    57 HEAP
    These were taken a few years ago by my neighbor.
    You can see where the exhaust is hitting the ground in this shot.
    The radiator shows up well in this one.
  14. lothiandon1940
    lothiandon1940
    Very interesting. Should be useful for some diagnostics.
  15. J. A. Miller
    J. A. Miller
    from Central NY
    That's pretty neat, but lets see some V8 shots!
  16. Martin_F
    Martin_F
    Very cool, Sam!
  17. jeta12
    jeta12
    So cool.....Love the shots of the 57
  18. That could be very useful in conjunction with your normal temp gun!
  19. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    I can grab temperature readings from anywhere on the image, just like I'm using a temp gun. It's a beautiful piece of equipment.
  20. 34toddster
    34toddster
    from Missouri
    Do you know how hot the white area on the exh manifold is? Cool Pics!
  21. Double cool! Would be nice to have at Bonneville when tuning.
  22. HOTRODPRIMER
    HOTRODPRIMER
    Cool photo,,well actually a HOT photo.:D HRP
  23. I used to do thermal imaging for a living. Did you notice the rear of the 57's front fender is warmer? Engine compartment air is heating up that area, but not the front of the fender. Fresh air vents are in the way.
    Can use the thermal gun to find dead cylinders or blocked radiator tubes.
  24. theHIGHLANDER
    theHIGHLANDER
    Hi-tech meets old stuff. Bore scopes, thermal imaging, and some worry about the internet's role in this stuff?
  25. Fenders
    Fenders
    Light painting. An old technique using a new tool.
    Never thought of that. Way cool.
  26. 57 HEAP
    57 HEAP
    The guy that took the pictures of my car used the camera on his job. He would photograph electrical panel boxes, bearings on moving parts, all kinds of stuff. If the photos showed heat, then there was a possible problem and it could be repaired before a break down.
  27. EnragedHawk
    EnragedHawk
    from Waco, TX
    Man, I dig those shots. Awesome.
  28. Chuck R
    Chuck R
    That is way cool. The colors are very pleasing to the eye. Thanks for posting.
    chuck
  29. OL 55
    OL 55
    I need one of those camera's to locate the radiant heat tubes in my garage floor, but they are so damn expensive!!! :eek:
    I'm surprised that the "off shore" industries have not started selling cheap knock offs at Harbor frieght stores yet! :rolleyes:
  30. 57 HEAP
    57 HEAP
    If you know any Firemen, ask them if they have a camera. Our local department has one to check for hot spots behind walls.
