Hot Rods Inland Tool Shifter
Discussion in 'The Hokey Ass Message Board' started by earlymopar, Jan 15, 2021.
  1. earlymopar
    earlymopar
    I'm sifting through things for my brother's estate and ran across this Inland Tool shifter. I know a little about them but I've had difficulty trying to find actual details on model #s, etc. Anyone have any references for these or can point me in the right direction?
    20210114_132320 (2).jpg 20210114_132416 (2).jpg 20210114_132423 (2).jpg 20210114_132438 (2).jpg
    dana barlow and loudbang like this.
  2. 41rodderz
    41rodderz
    from Oregon
    I am thinking they were installed in cheap models with a manual trans ‘60’s ,’70’s . Performance muscle cars would get a Hurst.
  3. DDDenny
    The rods look like they are each progressively longer than each other, first thoughts are Saginaw, maybe Monza, that boot looks oem(ish).
    Pretty sure ITM made shifters for various oem applications.
  4. Boneyard51
    Boneyard51
    They were standard equipment on a lot of Chevys, in the sixties! I bought one a couple of years ago at a junk store and inquired about them!
    They look like good shifters.
    Bones 199DFE40-7833-47D0-84CD-673CACC4C9C8.jpeg 30979102-F7DA-4227-84C7-5BA1BAF7E9CE.jpeg
    alanp561 likes this.
  5. dwollam
    dwollam
    Bones, yours looks like a Mopar shifter. They used them too.
    Dave
    Boneyard51 likes this.
  6. DDDenny
    Looks to be GM (B) body Greg, maybe late 70's.
  7. Boneyard51
    Boneyard51
    Wow! Thanks! I just inquired about the Inland Tool shifter and it took me to Chevrolet! I hope it is a MoPar shifter, should be more valuable than a Chevy!
    Bones
    deathrowdave likes this.
  8. BJR
    BJR
    Why would you want to shift your inland tool? Pants too tight?
    loudbang and alanp561 like this.
  9. Fordors
    Fordors
    Looks like @DDDenny nailed it, lay it out with the shift levers to match this side cover. The span between 3-4 and
    1-2 is 3 11/16” and 1-2 and reverse is
    1 3/16”.
  10. earlymopar
    earlymopar
    Thanks Doug, Fordors. I was pretty certain it was Chevy but was not clear on the approximate year. Wow, 70's era is later than I thought. I knew it wasn't Mopar as most if not all of those had the reverse lock-out (T-lever). I did think it was unique that it appears to mount on the side of the side of the transmission (floor) hump. Now that you say that, my brother did have a 78-ish El Camino with a 4 speed. Perhaps this was the factory piece and he swapped to a Hurst set up......?
  11. My early production '68 Road Runner 4 speed had an Inland shifter. Broke one lever twice, can't imagine how!
  12. earlymopar
    earlymopar
    383 car? Those were a lot of fun!
  13. low down A
    low down A
    yea mopar used them until 68, your's is not mopar look on ebay tons of them you can't hardly give them away and if you ever tried to shift a high reving motor with one you would no why JUNK
  14. oldiron 440
    oldiron 440
    I think mopar used them on the OD 4 speed in the 70s.
  15. DDDenny
  16. finn
    finn
    68 Roadrunner had them.
  17. DDDenny
    I'm recalling those and the later Hurst pistol grip shifters have quite convoluted handles on them compared to this one.
  18. Starlinerdude
    Starlinerdude
    from Washington
    The were commonly used on 2nd generation GM F-bodies (camaro,f-bird)also along with a lot of other rigs.
  19. deathrowdave
    deathrowdave
    from NKy
    Inland is a good good company . I have a couple of them . They are top shelf stuff .
  20. earlymopar
    earlymopar
  21. Elcohaulic
    Elcohaulic
    Is that the shifter Grumpy Jenkins used? It was an off brand from some little shop in Pa.. They said the action was like an expensive Swiss time piece
  22. southcross2631
    southcross2631
    It was the first thing we changed when we started racing them. They hung up when you are really racing hard.
    egads and Truckdoctor Andy like this.
  23. DDDenny
    He also used the P&G shifter from another little shop in Portland Oregon.
  24. Mr48chev
    They were commonly used on a lot of cars but more often than not got replaced with a Hurst after the car owner got tired of the sloppy shifting. A buddy gave me one years ago that he had replaced with a Hurst that I used on a three speed in a car I had then. We just moved the reverse lever to reverse position and tied it down with bailing wire and bingo it was a still sloppy but free three speed floor shift. It was still better than the horrid excuse for a shifter that came with the car though.
  25. finn
    finn
    It the 68, and, if I recall, not the 69, either.
    By 70 they had bends for the pistol grip.
  26. earlymopar
    earlymopar
    What year do you think P&G went out of business? I have one of the "P&G Gappers" for setting valve clearances on solid lifter engines. I think they were pretty innovative for the time.
  27. DDDenny
    I don't know Greg but I bet the boys in Warminster puckered a little the first time they saw those P&G shifter decals on Grumpys' car!
  28. earlymopar
    earlymopar
    Ha. No doubt. I think I'll do a little digging on P&G history!
  29. earlymopar
    earlymopar
    I forgot to ask....what transmission/s does this side cover fit?
  30. Fordors
    Fordors
    I didn’t mention it, as DDDenny already had, but it is a Saginaw, it was introduced in ‘66 and I guess GM used them for 15 or 20 years. Best suited to low horse engines, won’t take a lot of torque.
    Sorry for the oversight.
