inline 6 builds
Discussion in 'The Hokey Ass Message Board' started by 64cummins, Aug 6, 2012.
  1. Chris F100
    Chris F100
    answer to 64 ***mins - its a regrind of the stock cam -lift intake and exhaust 399 - duration 260 I and E - I open 20 close 60 - E open 60 close 20
    hope that helps
  2. shivasdad
    shivasdad
    from Texas
    Here's a Ford 300 I redid for a customer in an OT Bronco. Stock rotating ***embly, Comp 262 cam, drilled and tapped for 7/16 rocker studs, guideplates, Offy DP intake, Holley 390cfm, later EFI exhaust. Converted to DSII ignition box, the owner didn't want points. Deleted the smog stuff and threw out the catalytic converter. It sounds awesome even going into a single exhaust.
  3. MainProp
    MainProp
  4. pbr40
    pbr40
    from NW Indiana
    It's in the car now. I'll see if I can't get an updated pic! There are some cool liners on here!
  5. Normbc9
    Normbc9
    I do inlines in 4, 6 and 8 cylinder configuration. When done right they are a good stable engine platform. The 292 in the photo shifts at 9,000 RPM and engine Dyno's at 748 HP. The 235 with the triple carburetors has a full roller cam setup including the rockers too. It cranks out 442 HP on the Dyno. There is real potential. The strongest inline I have seen is the Ford 300 six. It has some real top notch possibilities. All it takes is money.
    Normbc9
  6. HOTFR8
    HOTFR8
    I am not a Chevrolet fan but I have to say that looks very neat and tidy.
  7. KenCrete
    KenCrete
    from Milwaukee
    My 54- 235 so far. I painted it up, threw it in my bel air, & hit the road. dual carb setup in the future.
  8. 64cummins
    64cummins
    from kansas
  9. MainProp
    MainProp
    Thanks HOTFR8.
  10. slackcat
    slackcat
    Nice build Chris F100
  11. BrianInPa
    BrianInPa
    from Milton
    Boucher Racing,
    I like your truck. I'm putting a 292 in my '65 Chevy short fleetside. I'm considering a turbo, but haven't decided for sure yet.
    What transmission are you using?
    brianinpa
  12. boucher racing
    boucher racing
    from nashville
    Thanks, a turbo is great for power. It is a bit tricky to set up though. I a running a T5 out of a S10.
  13. I built an .080"-over 261 for my '54 Chev. Powerglide head, Howards cam/ lifters/ pushrods, full filtration, Power Stroke one piece rear main seal, ported head, Cliffords headers, offy dual with 2 Carter-Weber progressive 2 bbls, etc... Behind it is a modifies S-10 T5 and a 10 bolt limited slip with 3.73:1. I plan on doing a tech article on the engine mounts I built for it. Stay tuned...
  14. 64cummins
    64cummins
    from kansas
    Any ideas on Holley 1904 jets for my ford 223 with deck head and 3/4 race cam
  15. sixfiend
    sixfiend
    This is an inspiration. My 54' 235 was getting water in #4 cylinder and I finally pulled the head. TG it was cracked and not the block. I've since found a head, tanked, beaded and magnifluxed. The head was surface cut just for clean up. How much can you mill these heads?
    Any way your pictures got me thinking I should pull the short block and do it over. Thanks for posting them.
    Pat Hennebery Jr.
  16. 64cummins
    64cummins
    from kansas
    look is that 3 carbs[​IMG]
  17. Crookshanks
    Crookshanks
    Dig that pickup 64***mins!
  18. 64cummins
    64cummins
    from kansas
    Thanks and I wish I could buy urs it is very cool
  19. Crookshanks
    Crookshanks
    I chickened out and fell in love w/ it again. Can't sell it!
  20. BISHOP
    BISHOP
    300 six
  21. 64cummins
    64cummins
    from kansas
    Bishop what is carb setup
  22. BISHOP
    BISHOP
    3 autolite 1100 series fomoco carbs. Hand built intake, hand built stainless linkage.
    All new carb parts through PonyCarbs.
  23. 64cummins
    64cummins
    from kansas
    Well it looks very nice wonderful job
  24. badsix
    badsix
    [​IMG][​IMG]
    my 270 JIMMY
  25. LowFat48
    LowFat48
  26. BISHOP
    BISHOP
    That looks crazy.
  27. Blake84
    Blake84
    Hey ***mins......I got a question for anyone really.....I have 59 f100 with 223 inline 6.....part of me wants to put in a 351 Windsor witH an aod and part of me really digs the original inline 6....really feels old school and feels like a piece of history.....my problem is I obviously don't get a lot of Power out of my engine and I'm curious if the upgrades you have made have made a noticeable difference in power....I know it's not going to be anything crazy but I'd like to keep up with traffic on the hwy 65-75 mph.....not sure if I should dump the money into what I have or go with new set up....any advice anyone?
  28. 64cummins
    64cummins
    from kansas
    I pm you my number give me a call I have a good recipe for the ford 6
