Inline 6 chevrolet engine
Discussion in 'The Hokey Ass Message Board' started by billjharris, Nov 16, 2007.
  1. rainh8r
    rainh8r
    The inliners have lots of 261 info on their site including casting numbers to check your block with. The 54's are the desired blocks because they can be bored almost 1/4". The year is stamped on a pad next to the distributor-the first 2 digits should be the year but they are sometimes very faint.
    GMC's have the engine size stamped on the same pad next to the distributor-the first 3 digits are the CU (228/248/270/302)
  2. oldcars.acadia
    oldcars.acadia
    The 261's that I have had (55-59) have been easy to spot in that they are painted yellow.
  3. lrseclipse
    lrseclipse
    from Dallas, TX
    261's were in the 54-62 chevy pickups and also in the GMC pickups until GMC came out with their v6 engine :)
  4. OldSub
    OldSub
    That is not an accurate statement regarding the GMC's.
    Most, and maybe all, Canadian built GMC pickups had Chevy motors. There is some debate over whether any of them had GMC motors and I don't know the answer to that. A GMC of those years with a Chevy motor is either Canadian or the subject of a swap.
    The earliest US made GMC trucks and pickups had Oldsmobile or Pontiac inline sixes until the GMC 228 was introduced about 1940 (don't remember the exact year).
    Over the years that motor grew to the 248, 270 and 302. The 302 was also used in military applications starting pretty early.
    From the introduction of the 228 until 1955 US made GMC trucks came with GMC motors. When the V-8 era began in '55 the six cylinder equipped trucks still used GMC motors, but the V-8's were from other GM makes, mostly Pontiac.
    The GMC V-6 became the standard GMC motor in 1963. These days GMC trucks have Chevrolet motors.
  5. Terry Johnson
    Terry Johnson
    Actually, if I remember correctly, the 261 was a "raised deck" version of the 235, meaning the block was cast taller to allow a longer stroke. TJ
  6. Terry Johnson
    Terry Johnson
    Hey, I just "inherited" the old family '29 Chevy 1 1/2 ton truck. All original. Used to run good, but hasn't run in 12-15 years. Engine has been full to the top with oil for storage, farmer style. I think I'll drain it, fill it back up with diesel for a day or two and drain it again before I attempt to get it running. Any better ideas? Should I pull the head and re-gasket the top end first. Any opinions? TJ
  7. PAUCHO
    PAUCHO
    The 261 is a GREAT engine.....here's another site to check out ........"Langdon Stovebolt"
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    No, the stroke is the same as a 235; in fact, both engines use the same crankshaft. The extra 26 cubic inches are the result of a 3/16 inch bore increase.
  9. lrseclipse
    lrseclipse
    from Dallas, TX
    oopsies, didnt mean to misinform. great info, thank you!
  10. Snarl
    Snarl
    261's were used from '54-62 in the 60 series trucks and in '63 in some 4x4 trucks.
    Only the '59-63 USA made 261's had the full flow oiling. All were full pressure though.
    FYI, FULL PRESSURE DOES NOT MEAN THE SAME AS FULL FLOW...
    deck height is the same as a '53-62 235.
    Considering the options you have these days with either a shortened water pump or an adapter plate to use the older style pump, I can't see why a '54 is going to be the better choice, since it has byp*** filtration and you need to shim the bearings. I'll take the '59-63's...
    Canadian Pontiacs used Chevy 261's in some of their cars, but they were all hydraulic lifter and byp*** filtration.
  11. mtkawboy
    mtkawboy
    I hope with a little work & time that they will be able to get that new Chevy V8 over 132hp. Time will tell
  12. newstranger
    newstranger
    wha?
  13. Sorry to hear yer slumming with Doc:D Tell him howdy, dont get up that way much anymore.
  14. Jasper6120
    Jasper6120
    from Australia
    Why are the older water pumps better? I bought an older style water pump for my '53, then realized it's 235 was from a later car (has the later model water pump). Should I buy an adapter plate for my new pump instead of swapping and getting a later model pump?
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The early water pump isn't BETTER than the later pump, it just makes retrofitting the engine into a '37-'53 car easier, since you don't have to shorten the pump, relocate the radiator, or buy a special pump to do it. Plus, if you're putting it in a '52-'53 car, the '54 motor mount bosses work without modification.
