Technical Inline Fuel Pressure Gauge
Discussion in 'The Hokey Ass Message Board' started by Truck64, May 20, 2018.
  1. Jmountainjr
    Jmountainjr
    OK. You used 5/16" tubing. The common female branch tee for 5/16" tubing has a 1/8" pipe port on the side so it's a direct fit to the common fuel pressure gauges. Good luck should you decide to do it. You might even find a short piece of tubing at NAPA that you could add in as you seem to want avoid any cutting and flare work.
    Truck64 likes this.
