inline six ID
Discussion in 'The Hokey Ass Message Board' started by Frankenshovel, Nov 6, 2007.
  1. Frankenshovel
    Frankenshovel
    Can anyone please help ID my sixer. I've looked extensively with no luck. The casting # on the block reads GM 2775308 and yes I double checked. I've checked numerous ID sights with no luck. Any help would be appreciated. thanks.
  2. Lucky444
    Lucky444
    Have you tried here?
    http://www.inliners.org/
    There is a casting #'s page and if you can't find it there ask on the bulletin board. Everyones really helpful.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The date code would help. It'll look something like A 4 7, or C 28 3.
  4. PeteFromTexas
    PeteFromTexas
    Look just above the starter. there should be a code resembling what hethen just said.
  5. squirrel
  6. Frankenshovel
    Frankenshovel
    Wasn't having much luck with inliners.org. The block casting #(behind the starter on the p***enger side) read as given. The casting date reads"G 10 73. OK, It's a 73. Does that make it a 250? Because I can't find that casting code.Thanks again.
  7. Frankenshovel
    Frankenshovel
    BTW, below the casting # reads" Hecho en Mexico". Don't know if that makes any difference.
  8. PeteFromTexas
    PeteFromTexas
    If it says 73 that usually means it was cast in '73 to go in a '74 year model. Which makes it a '74. The new models came out in September I believe. Or that is the way it was done in the 50's if I'm not mistaken. Someone correct me if I'm wrong.
  9. squirrel
    mexican engines had different casting numbers, right? so it's not surprising that you can't find it in the usual lists.
    Sounds like it's either a 250 or a 292, the 292 is almost 2" taller than the 250. The 250 has the side motor mounts exactly opposite each other, the 292 has one forward of the other a couple inches.
  10. PeteFromTexas
    PeteFromTexas
    The code there is as follows. The letter is for the month. The numbers are for the day and year. So yours would was made on July 10th 1973 and it went into a 74 year model car or truck.
  11. shpotty
    shpotty
    from New Jersey
    G1073 stands for July 10th, 1973.
  12. Snarl
    Snarl
    There's also a stamped number to the rear of the dizzy that can sometimes help. Chilton and Motors manuals usually have the stamped codes listed. Otherwise, take that stamped code to your local GM dealership. They should be able to pin it down for you.
  13. Frankenshovel
    Frankenshovel
    The # stamped on the pad behind the dizzy is ce301760. I'll go take a look at the motor mount location. Thanks squirrel and everyone I've been pulling out what's left of my hair. I cant move foward on this until I'm posotive what the hell it is.
  14. squirrel
    sounds like an over the counter replacement engine. I had a few Mexican replacement 292s that came out of UPS trucks, they'd wear out several engines in the life of a truck...eventually they switched them over to the 4.3 V6.
  15. Frankenshovel
    Frankenshovel
    Thanks again guys. By the look of the mounts it's a 250. BTW, does anyone know of a sight that has exploded views/ diagrams of this motor?
  16. squirrel
    if it's a 250 the side covers will look like this
    if it's a 292 they will be a lot taller, like this:
    The old Chevy parts catalogs (that the dealers had) have some exploded views, the factory shop manuals have some more.....I like old Chevy publications....if you need specific info pm me I could probably scan a few pages.
  17. PeteFromTexas
    PeteFromTexas
    You are the man Squirrel
  18. Frankenshovel
    Frankenshovel
    No kidding! Thanks again.
  19. shpotty
    shpotty
    from New Jersey
    CE Engine information:
    "Another type of stamping found on some blocks is the "CE" code. You might see something like this "CE123456" on the front pad of the block deck on the p***enger side. The "CE" which has been known to stand for "Chevrolet Engine" or "Crate Engine" was used on blocks that were warranty replacement motors. The "CE" prefix was also used on "over the counter" blocks and engines. If a customer had problems with their original engine, while it was under warranty, it would have been replaced with an engine that was stamped "CE" with a number following it. The number following the "CE" code was the serial number for that particular engine. Also if someone purchased a new motor from the Chevrolet Parts counter, the front pad on the p***enger side of the block may have been stamped with a "CE" code.
    A number of crate motors made by GM in Mexico, may have an "M" or "ML" prefix stamped into the front pad of the block followed by a series of numbers which is the serial number of that particular crate replacement motor. You may also see a raised casting on the block or heads of "Hecho en Mexico" which means "Made in Mexico". Many of the new GM crate motors are being made in Mexico. Later model crate engines, sold over the counter by Chevrolet or GM Performance Parts, may have different prefix code identifiers stamped in to the front pad on the block, such as "ZZ3" or three letter codes such as "**A". "
