inline six in custom build
Discussion in 'The Hokey Ass Message Board' started by myoldcrap, May 11, 2012.
  1. myoldcrap
    myoldcrap
    Im building a 26 T Coupe with 235 chevy for power. The issue im wondering about is now that i have it mocked up in the ch***is. It seems to set off center to the center of the cowl. All the measurements front and back are the same. So im just not sure what to think. Can someone give me some help?
  2. Kinky6
    Kinky6
    Check the distance from each side of the block to the frame rail on that side. The valve cover sets off a little to the p***enger side, so that may be what you're seeing. Or its the whole intake/exhaust hanging off the other side thing that's throwing you off visually. Just measure the block sides, and the crank center line to both rails; if that's right, anything else is just an illusion. ;)
    Cool that you're using a six, BTW. Later, *****6 :cool:
  3. myoldcrap
    myoldcrap
    Every thing is centered in the frame rails. Yes it's the valve cover off center about two inches thats messing with my head. Just wanted to make sure thats the way it's supposed to be. thanks for the help.
