Inline Six Opinions?
Discussion in 'The Hokey Ass Message Board' started by Qparker, Jul 28, 2010.
N/A, Turbo, or Blown inline six?
Poll closed Jul 28, 2011.
  1. Naturally Aspirated (300HP/Ft.Lbs)
    48 vote(s)
    44.9%
  2. Turbo 10 pounds of boost (400HP/Ft.Lbs)
    27 vote(s)
    25.2%
  3. Blower 10pounds of boost(400HP/Ft.Lbs)
    34 vote(s)
    31.8%
  4. Regular intercooler
    8 vote(s)
    7.5%
  5. Water/Methanol/Alchohol Injection
    11 vote(s)
    10.3%
Multiple votes are allowed.
  1. nocoastsaint
    nocoastsaint
    There is no possible way for me to say '**** Yes' enough to the idea of the twin turbo eight.
  2. mart3406
    mart3406
    from Canada
    If you use V-belts on a 6-71 making 10 lbs.
    boost, you'll need more than "2 or 3" belts".
    More like 5, 6 or 7 V-belts....*minimum*.
    Even then, you'll have some slippage and
    running them tight enough to avoid a whole
    lot more slippage every time the engine
    suddenly changes speed, will put a lot of strain
    on the blower snout and drive bearings. That's
    why, 'back in the day' as soon as they became
    readily available, guys went to cogged Gilmer
    bets in the first place.
    Mart3406
  3. Qparker
    Qparker
    huh, I didn't think about that way...
    I just don't think a cog belt will look good, but, then again, performance>looks
  4. Qparker
    Qparker
    A road warrior setup? like from Mad Max? Where do the make/sell those? I've never seen one out side of my TV.:confused:
    Or tell/show me how to make one and I'll do it, I've just never seen one.
    sorry if I sound like a smart a$$, I don't mean to...
    Is anyone running one?
  5. mart3406
    mart3406
    from Canada
    No, no one is running one and you've
    never seen one, because outside of the
    minds sci-fi fiction writers and Hollywood
    movie makers who make pap aimed at
    the lowest common denominator of the
    generally already non-tech savvy public,
    the 'Mad Max-style' clutched roots blower
    set-up as shown in that movie doesn't
    exist and and mechanically, wouldn't and
    couldn't work. More bad news too. Believe
    it or not - and I've got this on very good
    authority - both "Star Trek-style" 'transporters'
    - along with dilithium crystals - as well as
    "Back To The Future" 'flux-capacitors' used in
    Delorian DMC-12 time machines don't really
    exist either!!! :eek::eek::D
    Mart3406
  6. BISHOP
    BISHOP
    Hahaahahahhaha. Man, this thread took a twist.
  7. Qparker
    Qparker
    that's what I figured, I just didn't want to look like a Dumb A$$ if Porkn****** waved his magic wand and posted pics, tech articles and other stuff to show me again how I knew everything... yesterday...
  8. hotflint
    hotflint
    Mart3406 is right. I am a millwright/industrial mechanic. The belts do have alot of slip and it takes alot of horsepower to turn over a 671 blower. If you really wanted to you could run an idler pulley system with it and whats called a double v-belt which is basically 2 v-belts glued back to back and idlers pushing inward. Modern cars, Grand Prix GTP, mustang cobra 5.4 L and ford lightning use a serpentine belt to run thier blowers but I beleive thaey are like 6PSI max.
    On alot of indusrtial machines they do use multi strand chain to drive blowers but again you would have to run an idler system and a cover. Try commercial Bearing or another industrial supply and they can provide access to anything you want that will fit the shaft of the blower snout, the bigger problem is coming up with something to fit on your front pulley to work with and may end up having to get something manufactured to work.
  9. mart3406
    mart3406
    from Canada
    'Back in the day' -ie - "BGB" (before Gilmer
    belts!:D) a few drag racers did use chain drives
    for their blowers. Chain driven blowers were
    largely abandoned (and I think eventually.
    even banned altogether by most sanctioning
    bodies) because of the danger of broken and
    thrown chains. Also, compared to a Gilmer belt,
    chains are pretty inefficient and absorb a fair bit
    of power. On the street, a chain drive would be
    even less practical too, because besides the
    danger of a broken or thrown chain flying around
    and cutting up and through everything in it's path
    :)eek:) the chain would need to be lubed
    constantly and the excess oil would be thrown all
    around the engine compartment.
    Mart3406
  10. hotflint
    hotflint
    in agreement with all except the lubrication. There is O-ringed chain available with sintered bronze bushings, largely used in motorcycle chains. I have seen 3 inch pitch chain get thrown and it cut through the guard, scary stuff..........
  11. PacaRacer50
    PacaRacer50
    no need to worry with turbos about belt slip... going thru that with my McCulloch VS-57 on the Hudson 308. yea it slips, looses about 1lb of boost but is one excellent street driving set-up. I used the wide pulleys from Paradise Wheels, small blower pulley for a R2 Studebaker, Idler from a 55 Kaiser and a flat 7.5" diameter Chevy crank pulley. 61" long belt.
    I would rather build turbo engines, either blow-through or draw-through as they each have there good and bad points.
    I vote for twin turbos but that's what I am building on the present project.
    Twin Corvair hybrid turbos (150hp exhaust and 180hp compressors), draw through two Autolite 4100 1.08 venture 4bbls, using a Twin-H Hudson intake on a 1954 Hornet 308 nascar spec 7X engine. Nothing on the entire car is newer than 1965 except for safety equipment, MSD 6BTM and braided fuel line to keep current with the rules at the drag strips.
    only problem I ran into with the twin turbo setup is how big the hole in the hood needed to be for the carbs, custom plenum and 1/3 of the turbos.
    Would rather build the long stroke 6's than anything, after all More stroke means more poke... like right in the compe***ions eye...
    PaceRacer50
  12. Qparker
    Qparker
    I'll go blown on this one for sure guys, and don't worry, I'll be sure to turbo one next time, just for those of you who've been wanting it. Maybe on a 235 or 261...
    Next Question: should I run progressive linkage or direct? Remember, 5 single barrel rochesters.
    If progressive, I'd like to fab up my own, and am confident in my skill, but honestly, I don't even know how progressive linkage works... Wanna help??
  13. Qparker
    Qparker
    or does anyone know of any other carbs that look good in multiples, can be found cheap/free, and can be added up to anywhere from 800-900cfm??
  14. tb33anda3rd
    tb33anda3rd
    n/a cool blown cooler.
  15. mart3406
    mart3406
    from Canada
    If you really want to run 800 to 900 cfm
    worth of carburetion on an n/a inline 6
    you definitely want to mount them on an
    I.R.-type manifold. Using that much
    airflow on a manifold with a common
    plenum will be too much and make the
    engine into a complete dog. I don't know
    where you'd find one (maybe here on the
    HAMB??) but 'Man-A-Fre' used to make
    a really cool looking 3X2 setup for Chevy
    6's that used three large-base Rochester
    2GCs on three small 'stub' manifolds that
    bolted directly to the ports. It wasn't a
    true I.R.-set-up, but with one 2bbl feeding
    a pair of cylinders each, without a large
    interconnecting plenum joining all six
    cylinders together, it was close enough to
    a true I.R. to work good with the
    large-base 2GCs
    Completely out of the realm or your
    common/cheap/free carbs requirement,
    but a true I.R. set-up and very cool - Clifford
    made a manifold for mounting three 45-48
    DCOE Webers on the Chevy and other inline
    6s. Extremely spendy for carbs, but an
    absolutely killer set-up!
    Mart3406
  16. Qparker
    Qparker
    I'm talking about 800-900cfm worth of carbs on a blown engine with the 6-71.
    If I went N/A I'd run it with a single Edelbrock 500cfm 4bbl, for ease of tuning on an Offenhauser Intake, but I'm seriously considering using the 6-71 and using multiple singles(or 2bbl's if needed).
    I'd run a Q-jet, but I'd have to get another 100cfm's out of it...
  17. uglydog56
    uglydog56
    My brother successfully ran a blown 400sbc on one 750cfm carb, shifting at 6800rpm. This engine had a roller cam, ported aftermarket heads, and ran 10's in a 3975lb car. Three 1 3/8" bore rochesters should be plenty for you.
  18. Qparker
    Qparker
    It'll run on 3 rochesters just fine, but it'll run out of juice high in the rpm's and boost.
    do you know how much boost he was putting to it? turbo or blower?
  19. uglydog56
    uglydog56
    8lbs of boost from a B&M blower. Your engine will not run out of juice high in the rpm's on 3 rochesters. Do your math. A 292 .030 over with 9# boost in drawthrough shifting at 5500 rpm with a premium cylinder head and optimized exhaust system needs around 743cfm. A 1 3/8" bore 2GC rochester flows about 357cfm. 357 x 3= 1071cfm. Ross' engine was bigger and spun more rpm and still didn't fall on its face on top. Spend some time in the junkyard at get a few of these carbs - take a machinist's scale with you so you get the right ones. Take the chokes of the outboard two, hook them up straight not progressive. Cool looking and will run fine if you pay some attention to getting everything the same in the carbs.
  20. Qparker
    Qparker
    (CIDxRPM)/3456x(Boost/14.7+1)=CFM
    (295x5500)/3456x(11/14.7+1)=820.779841
    Manufacturer Model:
    Rochester
    M Monojet:
    113
    CFM @ 1.5” Hg;
    160CFM @ 3.0” Hg;
    Throttle Bore, in. (mm);
    1 7/16 (36)
    Venturi Diameter, in. (mm)
    1 7/32 (31)
    M Monojet:
    148
    CFM @ 1.5” Hg;
    210CFM @ 3.0” Hg;
    1 11/16 (42)
    1 5/16 (33)
    M Monojet:
    177
    CFM @ 1.5” Hg;
    250CFM @ 3.0” Hg;
    1 11/16 (42)
    1 ½ (38)
    2GC:
    197
    CFM @ 1.5” Hg;
    278CFM @ 3.0” Hg;
    1 7/16 (36)
    1 3/32 (28)
    2GC:
    246
    CFM @ 1.5” Hg;
    352
    CFM @ 3.0” Hg;
    1 11/16 (42)
    1 3/16 (30)
    2GC:
    269
    CFM @ 1.5” Hg;
    381CFM @ 3.0” Hg;
    1 11/16 (42)
    1 ¼ (32)
    2GC:
    299
    CFM @ 1.5” Hg;
    423CFM @ 3.0” Hg;
    11/16 (42)
    1 5/16 (33)
    so say I used the biggest monojet, that'd put me at 177CFM @1.5hg, so it'd take 5 of them to make 885cfm. and 3 of them would only be 531CFM, and from what I've heard It takes alot to have too much cfm's on a blown motor.
    or I could use the biggest 2GC, at 299CFM @1.5Hg it'd take 3 to make 897, so you'd be correct on that one.
    I'd like to use monojets, but I may be stuck with the 2GC, seems how they're higher flowing...
  21. mart3406
    mart3406
    from Canada
    890 total cfm, theoretically at least,
    would be too much for a roughly 300
    cubic inch, naturally aspirated engine
    using a conventional 'plenum-type'
    manifold. However, if you use an a
    true (or near true) 'isolated runner'
    style manifold like the old 'Man-A-Fre'
    3X2 or similar, 890 total cfm would be
    barely enough. And if you use a blower,
    depending on the amount of boost
    pressure, hp level and rpm range you
    plan to run, your cfm calculations go
    right out the window.
    Mart3406
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I vote for a normally aspirated engine in that type of vehicle.
  23. LB+1
    LB+1
    from 71291
    "Theoretical inline engine building"
    Go out in the shop and get your hands dirty first.
    The IF factor - Will never end!
    How ever it is the cheapest way to go. :p
