Technical Inner door handle escutcheon
Discussion in 'Traditional Hot Rods' started by James Mundstock, Feb 13, 2024.
  1. James Mundstock
    James Mundstock
    I have a rare 1937 car that the aftermarket does not make replacement door handle escutcheons. I need them shallow in height and the ID needs to be 11/16. Can anyone recommend a standard car that I could buy aftermarket replacement escutcheon. A lot of ads do not have dimensions. Thanks in advance for the replies. If you are wondering, it is a 1937 Hudson Terraplane.
  2. Dang.
    Now I got to google a new word
    '29 Gizmo and Bob Lowry like this.
  3. onetrickpony
    onetrickpony
    from Texas
    I can't directly answer your question but I have made an escutcheon plate using a big flat washer covered in chrome vinyl wrap.
  4. Bandit Billy
    Bandit Billy
    Do they need to be spring loaded?
  5. DDDenny
  6. I think you could make them and have them look very Henry!
  7. Bandit Billy
    Bandit Billy
    I bought these for my pickup. They are spring loaded to cover the pin that secures the handle. See notes below.
    dirt t and Packrat like this.
  8. poco
    poco
    from oklahoma
    I hav e several for ford cars 38 thru 48. Don
  9. 3d print it, if you access to someone.
  10. lothiandon1940
    lothiandon1940
    ...But he wants them to look Hudson.:D
    34 GAZ likes this.
  11. DDDenny
  12. Try the plumbing supplies, there are various types sold for covering the holes in tiles and walls around outlets. Most are stainless or chrome.
    Packrat, lothiandon1940 and Just Gary like this.
  13. lothiandon1940
    lothiandon1940
    ....Wow, never thought of this.:)
  14. Yep,36roadster's suggestion about plumbing supply companies is a good one........they are hard to see but I have had them on my 1940 Dodge 4dr since the mid 1970's......nice chrome and in various diameters......this is the only pic I could find that has the door handles in it........andyd
  15. lothiandon1940
    lothiandon1940
  16. enjenjo
    enjenjo
    from swanton oh
    In the 30s most smaller auto manufacturers used door and window handles and attaching parts made by the Ternstedt Division of GM. You may fond that other companies used the same parts.
  17. Do you have a photo of an original that you're looking for ? There are over 80 listings on ebay under hudson terraplane door escutcheon some don't say what the fit so you need to compare to what you need.
    lothiandon1940 likes this.
  18. Doug G
    Doug G
    from Manheim Pa
    I tried to find escutcheons for a custom application also. Difficult because reproduction company's do not give dimensions ? You think they would sell more parts with that little detail ! Good luck
  19. gene-koning
    gene-koning
    I suspect escutcheons from a 30s -40s Dodge will work. Those are not hard to find online. I'd contact the company listing them and see if they will measure the diameter of the hole.
    I believe I have an old window crank in the garage. If I remember I'll measure a Dodge one.
