Technical Inner door plastic
Discussion in 'The Hokey Ass Message Board' started by johnfin, Nov 2, 2025.
  1. johnfin
    johnfin
    from Florida
    Where can i get the clear inner door plastic. Its .010" thick. Visqueen is thinner.
  2. RodStRace
    RodStRace
    Check your local hardware store, they should have various sheets in different thicknesses. If no go, the web offers everything.
  3. 49ratfink
    49ratfink
  4. RodStRace
    RodStRace
    The typical sheet quan***y is too much for a car interior. Look for super HD trash bags, drop cloth (plastic) or other smaller amounts.
    alanp561 and 1971BB427 like this.
  5. 57Fury440
    57Fury440
    I got some from a fabric store. They had it in a couple of thicknesses on a roll. You could buy as much as you needed.
    sidevalve8ba and RICH B like this.
  6. evintho
    evintho
  7. Wanderlust
    Wanderlust
    Clear vinyl (no texture) shower curtain
    alanp561 and RodStRace like this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. HOTRODPRIMER
    HOTRODPRIMER
    I used the contractor size trash bags cut to fit inside the doors on the Ranch Wagon. HRP
  10. deathrowdave
    deathrowdave
    from NKy
    I used the plastic that goes under a vinyl floor . It is provided in a roll works well.
    mad mikey likes this.
  11. johnfin
    johnfin
    from Florida
    All the stuff you buy at the big box stores is too thin. It needs to be .010".
  12. milwscruffy
    milwscruffy
    upload_2025-11-3_7-29-19.png 10 mil is .010 thick.
  13. stuart in mn
    stuart in mn
    As mentioned you can get many different thicknesses of plastic at the big box store, but does it really matter? All it has to do is provide a moisture barrier, and once it's installed and the inner door panel is in place it's not like it's in danger of being damaged.
    alanp561, vtx1800 and SDhotrod like this.
  14. Fat47
    Fat47
    I went to a local furniture store and the manager gave me the plastic sheets that mattress' come in. It was thicker and worked great. And, it was free.
  15. johnfin
    johnfin
    from Florida
    What was the original material they used (white) to attach the plastic. its like a sticky putty.
  16. Jim Bouchard
    Jim Bouchard
    I use this product to hold the plastic on.
  17. ric
    ric
    In my shop we used 3M Ribbon Sealer, part #8610. Bought it from my local Napa store. Looks like strip calk but MUCH stickier.
  18. nochop
    nochop
    from norcal
    Spoken like a true retired dude
  19. Anything listed as 10mil will work. Extra heavy duty trash bags from Amazon.
  20. willymakeit
    willymakeit
    What mil visqueen are you looking at, It comes up to 100 mil, finding it in small quan***ies might be a issue. Check some construction supply houses not the box stores.
  21. Bugguts
    Bugguts
    I used clear shelf contact paper from the local hardware store. (It’s used to cover shelves in cupboards. Comes in all sorts of patterns)
    It’s thick enough and...it’s adhesive backed and sticks just enough.
    I removed an inner door panel this summer after installing in 09’and it still looked just like it did when installed.
