inside door locks 27 ford rpu
Discussion in 'The Hokey Ass Message Board' started by rd martin, Feb 22, 2012.
  1. rd martin
    rd martin
    from indiana
    can anybody give me any ideas on some inside door locks for my 27 ford rpu? i have latches in the doors, but no locks. i know these doors i going to pop open without any locks. i dont want to put any shed door **** on here, so give me some ideas , and if you have any pics they would be great1 thanks
  2. chaddilac
    chaddilac
  3. lowball27
    lowball27
    Now this may sound odd or maybe not. I seen a guy had used door lock mechanism from a VW rabbit in his model A pick up doors. He had adapted the mechanism to his stock door handles and fitted the stricker pin to the door frame. Did an awesome job and closed nice and secure.
    I thought of using a similar set up on my T coupe once I get to that point. Mainly for safety.
  4. I had a 27' never had the doors pop open?
  5. Dirty Dug
    Dirty Dug
    I don't see why they would pop open if your body is well built. Try it first before you go to Ace Hardware.
  6. striper
    striper
    Mini Bear claws. $15 each
  7. Shaggy
    Shaggy
    from Sultan, WA
    My dad always beat into me to not lean on car doors, problem solved
  8. My latches are so tight on the track roadster that I have to use the handle to open the latch to close the door. Besides that though I couldn't fall out through that door opening on a bet.
    Charlie
  9. Dave Mc
    Dave Mc
  10. JMel
    JMel
    My p***enger door would constantly pop open on bumps...which constantly pissed my wife off. It was one of her two rules that she had while i built the car - 1) She has to be able to drive it (no manual ******), and 2) the doors must not pop open.
    1 out of 2 wasn't too bad. New striker plate from speedway solved the problem though. The original one was somehow or another banged up and couldn't latch properly. You could close the door, push, pull, shake, rattle, kick, and cuss, and the door would not come open, but the first minor bump you hit on the road.....whoops...there it goes.
