Gentlemen Did the search for inspection cameras with no hits. Anybody using these units to peek inside there engine? Horrible Freight has one as well as TP. Each is different but reasonable under $150.00. Any suggestions? How good is the actual image.Junk or worth obtaining? Oldmics
i bought a hf once, to the trash i bought a milwaukee tool camera it was in the $250 range and worth it, but i do not think you will see much in a engine good or bad, i used mine in when buying cars to check the back side of rocker panels and the underside of floor pans for rust or bondo, it worked very good for that but did take some trial and error to get a handle on what i could do with it i suppose you could view into a spark plug hole, but the cable does not make realey sharp curves. we do use it around the shop in the maintenence dept to find stuff in the walls etc.
