Inspection door
Discussion in 'The Hokey Ass Message Board' started by rebelrat, Mar 12, 2010.
  1. rebelrat
    rebelrat
    Anyone know where I can get steel inspection doors to put in a floor. I need one 8'' x 8'' and one 12'' x 12'' with hinge. frame and some kind of catch. I know MAS used to have them but i believe they have closed.
    Thanks guys
    Andy
  2. Why not make one?
  3. Salty
    Salty
    from Florida
    I got a stainless steel inspection door with latch for like 12 bucks from.....**** gimme a min....
    Looked at my reciept and it's from CPP Industries....looked at their site which has changed a ton and couldnt locate it (that site is a straight ***** to navigate) might call em or get a cataloge (I ordered over the phone with a paper cataloge....)
    Its a very nice peice, flush mount with an inset door on piano hinges with latch, all stainless...yeah I coulda made it...but for 12 bucks but my time it woulda taken me to fab that flush mount unit I think was worth the lunch money I used to buy it.
  4. jetnow1
    jetnow1
    from CT
    Front cover plate off an old electrical panel would be a cheap and
    easy way to get one- ask any electrician to save you a couple.
  5. You can make them and do not need a hinge. Keep a tab on one side, bend tab 90 degrees and ben back to give it a "step". The "step" will fit onder one side an a small screw will fasten it on the others. *****in sells them for MCs but they are easy to make, you dont even need a brake. Vise or clamp it over the edge of the work surface.
  6. junk yard kid
    junk yard kid
    Motor home supply stores
  7. Chopped52deluxe
    Chopped52deluxe
    from illinois
    rockvalleyantiqueautoparts.com has them I believe.
  8. i make them , but for the step i use one of those panel flangers
  9. coupster
    coupster
    from Oscoda Mi
    I used a toaster cleanout door, came with everthing you listed, and free.
