install sending unit with permatex?? Is that ok
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Jun 20, 2004.
  1. Toqwik
    Toqwik
    Putting a sending unit in a metal tank, is permatex ok to use to help the gasket seal, or should I use something else?TOQWIK
  2. SKR8PN
    SKR8PN
    If you mean silicone type sealer,don't do it. If you meant the OLD style of Permatex sealer,go ahead.
  3. Deyomatic
    Deyomatic
    from CT
    What are you doing with the permatex? Just trying to make a gasket? You could make one out of cardboard or gasket material (which is sold in sheets at most auto parts stores). There is also some stuff called Shellac that wouldn't be broken down by the gasoline, but from what I hear, it is impossible to ever get the pieces apart again if you use it.
