? installing manifold studs straight 8 Buick ?
Discussion in 'The Hokey Ass Message Board' started by chub chub, Sep 1, 2009.
  1. chub chub
    chub chub
    After all new valves, springs, guides ect., I'm reinstalling the head on my 52 Buick Special with the 263 straight 8. I reinstalled the studs that hold the intake/exhaust manifold on. When I did so, I threaded them in until they bottomed out in the head.
    Now that I am trying to reinstall the manifolds, there doesn't seem to be nearly as much thread to install the nuts on the studs. I don't have everything tight, so there is still room for gasket compression ect., but it just doesn't seem like enough thread. I can barely get the nuts started.
    The threads on the head side are 3/4" and are fully seated in the head. Is it safe to back them out a 1/4" or so so that the nuts can fully thread onto the other side of the manifold? Is that was done at the factory?
  2. Ruiner
    Ruiner
    Rule of thumb, you need 1 1/2 times the diameter of your bolt for depth of thread engagement...eg: 1/2 inch bolt needs 3/4 of thread depth to properly hold...so if you have 3/8 inch studs, you need 9/16 of threads in the block...does that help?...
  3. chub chub
    chub chub
    That does help. I guess they won't work their way loose, it just seems sketchy that they would be only partly threaded into the head.
