Installiny intake on 292 y block
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Oct 3, 2011.
  1. 56 ford custom
    56 ford custom
    from Socal
    Well the valley pan was a pain in my *** Now im installing the intake. Im using felpro gaskets. Do I need to use any sealer or anything besides the gasket? Also what are the lengths on the intake bolts?
  2. 56 ford custom
    56 ford custom
    from Socal
    No y block guys on tonight?
  3. 56 ford custom
    56 ford custom
    from Socal
    On the bolts I need to know what type,length and the grade. Thanks
  4. kennedy
    kennedy
    from TN
    Can't tell you off hand on the length of the bolts, but some are shorter than others. Be sure not to use to long of a bolt or it will bend a push rod..
  5. 56 ford custom
    56 ford custom
    from Socal
    Damn....so how far in do these need to go into the block? 1/2 or 1/4 inch?
  6. grovedawg
    grovedawg
    from Heber, UT
    I've always tried to bury as much thread into whatever I'm tightening equal to the diameter of the bolt. So, if it's a 3/8ths' diameter bolt, I try to get that many threads at a minimum into the nut, block, or whatever.
  7. grovedawg
    grovedawg
    from Heber, UT
    Don't know if that helps. I do remember threading the last two bolts on the block, where the water temp sending unit attaches (?) with a bolt that was barely too deep and it snugged up against the push rod. I had to shorten the bolt. But it was more of a "place-holder" bolt to fill a hole, rather than a bolt to tighten down the manifold. When I get home tonight I can check if no one else has posted.
  8. 56 ford custom
    56 ford custom
    from Socal
    Ok thanks grovedawg
  9. Blue One
    Blue One
    from Alberta
  10. 56 ford custom
    56 ford custom
    from Socal
    Yes I was going to buy that set but I cant see spending $60 plus shipping on fasteners that I can get from a local hardware store for nothing near that price. Also I really dont need stainless bolts. I might consider getting that set for my 56 sedan build since that is a higher dollar build.
  11. Blue One
    Blue One
    from Alberta
    That kit is not stainless and it does have all the bolts you need. How much is fewer headaches worth to you. Would be worth it to me.
  12. 56 ford custom
    56 ford custom
    from Socal
    Oh my mistake. I have called them before and they told me they only had stainless. Must have gotten "the new guy" that day. Well all I need now is intake and timming cover bolts.
  13. RichFox
    RichFox
    Enginering 101. 1 and 1/2 times the diameter of the bolt is the rule of thumb.
  14. 56 ford custom
    56 ford custom
    from Socal
    Thanks richfox. Still on the look for these bolts.
  15. 56 ford custom
    56 ford custom
    from Socal
    I think I got it all situated. Do I need lock washers on all the bolts for timming cover,water pump and intake?
  16. 56 ford custom
    56 ford custom
    from Socal
  17. 56 ford custom
    56 ford custom
    from Socal
    Well after going to home depot and a few auto part stores nobody had the bolts and studs that I needed.
  18. Tacho
    Tacho
  19. dana barlow
    dana barlow
    from Miami Fla.
    Ace or TureValue has a good nut/bolt pick,if ya don't have Nut & Bolt supply nere by
  20. Tacho
    Tacho
    Don't know how far you are from http://www.marshallshardware.com/ but they carry a lot of hardware. They have one location here in Salt Lake and another in San Diego.
  21. 56 ford custom
    56 ford custom
    from Socal
    I tried ace yesterday and didnt have the double threaded studs.
  22. RichFox
    RichFox
    Besides ARP, I looked on line and found a stud supplier. Had a good selection, but maybe not what you want. They may have been made for the Y block.
  23. 56 ford custom
    56 ford custom
    from Socal
    I ended up going to Prestige Thunderbirds in Santa fe Springs, CA. I highly recommend these guys! Well I got everything I needed. I bought the intake gaskets with the metal plates from them. Isnt the diameter of the hole too small?
  24. 56 ford custom
    56 ford custom
    from Socal
  25. 56 ford custom
    56 ford custom
    from Socal
    Any y block guys here this afternoon?
