instrument panel indicator and idiot lights
Discussion in 'The Hokey Ass Message Board' started by evil1, Apr 27, 2010.
  1. evil1
    evil1
    Instrument panel indicator and idiot lights...Why run them? Lets see what is being used and what they indicate?
    here is what im thinking of running in my car... green for turn, red for key on, Blue high beam, Amber? (not sure yet)
  2. HOTRODPRIMER
    HOTRODPRIMER
    They are cool but so big they will blind ya when they flash!:eek::D HRP
  3. a40lover
    a40lover
    I like your pannel, but agree your going to be brite!
  4. shmoozo
    shmoozo
    from Media, PA
    I would take a different approach to installing indicator lamps.
    Generally speaking I'd be inclined to have them on the same panel with the instruments.
    I'd have the turn signal indicators out at the far left and right of the panel in locations that would not ***ociate them with any of the gauges. If I had four-way flashers I'd use the turn signal indicators for those, too. I'd use amber for these. Amber indicates something I need to notice, but not something that needs to cause alarm.
    The high beam indicator would be top, center and blue. On your panel it would be above and between the speedometer and tachometer.
    If I was going to have a "key on" indicator, it would be above the ignition switch and green. For me, green simply indicates a normal operational state.
    Warning lights related to things like oil pressure, fuel level, water temperature, or the charging system would be red and adjacent to their respective gauges to draw my eye to the gauge which gives information about the thing that needs my attention. These would be the only types of things I would use red indicators for. A red lamp should indicate an emergency or at least something that requires my immediate attention. On your panel it looks like there would be room below your smaller gauges for these if you were going to have them.
    Depending on the rest of the interior design I might go with smaller lamps than you seem to have chosen, but that's a styling consideration which means it's a matter of opinion.
    That's my approach. I expect others would do this differently.
  5. Swifster
    Swifster
    My Studebaker has two indicator lamps. The blue for high beams and a single green for the turn signals. I would like to think you know which way you're turning, and you should be watching the gauges anyways.
  6. saveoursteel
    saveoursteel
    I use red for interior brake light indicator mounted high. , large red for low oil pressure Under 30 psi, green for ign on. Amber for foglights. No high beam for now, no turn signals. Vintage race car rat rod
  7. Pontiac Slim
    Pontiac Slim
    I taped into the brake lites power (at the lite itself) and ran a line back to two sm red lites on the dash panel.. I can tell if/when brake lights go on which helps with a mech. brake lite switch etc etc....
    Pontiac Slim
  8. mine
  9. evil1
    evil1
    I might move the lights up close to the gauges I'm no sure yet .. Thanks for the feed back guy..
  10. jpbanjo
    jpbanjo
    from Tulsa, Ok.
    Here's the setup an my '28 roadster pickup. I've had that "FIRE" lite for years and finally figured how to use it. It's connected to the "start" position on the ignition switch and lights up when you "fire'" the engine. Kinda dumb but I like it.
  11. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    If you need an ignition ON indicator, you need louder mufflers!
    Seriously, use red for oil pressure, even with a gauge.
    I've got similar lamps for my 29 Sedan, use resistors to dim them down a bit, especially the HI Beam indicator and the turn signals.
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    We've been using LEDs from the Shack for our indicator lights. Just make sure they are bright enough for daytime use without a top in an open car.
  13. marks914
    marks914
    Alliance Vendor
    How about something like this?
    We have alot of guys mount behind the panel for a more seamless look
    Mark
  14. evil1
    evil1
    More Please... bttt
  15. buzz4041
    buzz4041
    from Texas
    Heres mine. Plenty of light from these little jewels. I am using same approach in 40 pickup with the addition of red also for the suicide latch on the door.
  16. evil1
    evil1
    if the lights are too bright i just put a little piece of scotch pad in the lens and it looks perfect when lit
