1952-59 Ford Instrument Panel Voltage Reducers/Regulators
Discussion in 'Off Topic Hot Rods & Customs' started by raceron1120, Mar 10, 2011.
  1. raceron1120
    raceron1120
    A recent discussion started by chopd top included stuff about the dash/instrument panel voltage reducer or maybe more commonly known as a 'constant voltage' regulator. I looked around some other Ford sites on the 'net and found a pretty good article at the Ford & Mustangs page about them. I think this is what some of y'all were talking about re: converting 6volt to 12volt systems, and how to protect the gages?
    Part of it reads:
    ". . .On the back of your Ford’s instrument panel is the voltage limiter (also called an instrument voltage regulator). When you turn the ignition on, roughly 12-14 volts of electricity flow to the voltage limiter from the ignition switch. The voltage limiter reduces 12-14 volts to approximately 5 volts which is where gauges are happiest. If we ran a full 12 volts through the gauges, the damage would be swift and permanent. With a regulated 5 volts going to the gauges, it’s then a matter of completing the circuit from the gauge to the ground (negative)..."
    The entire article is here:
    http://www.mustangandfords.com/techarticles/interior/75259_instrument_electricity/index.html
    Hope this helps.
  2. sircampsalot2
    sircampsalot2
    It helps me alot! This is one of the questions Ive had on my mind since I bought my car and have been wondering what to do. Thanks for this it helps tremendously
  3. missysdad1
    missysdad1
    Thanks, Ron. The article you referenced is excellent. Simple and concise. I've bookmarked it for reference when I get to doing the instruments on both the Victoria and the Merc. I plan to retain the original guages on both cars and this should really help. Thanks again!
  4. chopd top
    chopd top
    from Florida
    EXCELLENT! Thanks for posting, Ron! This is a BIG help! I started my wiring today and I'm taking pictures. I'll get them on a new thread once I get it finished.
  5. raceron1120
    raceron1120
    I was looking at the new Mac's catalog (one with the green '56 Country Squire on front) and noticed there are 4 different voltage reducers listed at page 289. Prices range from $11.75 - $34.95.
  6. old lady's mad
    old lady's mad
    in borg warner its a vr1 available at most parts stores
  7. chopd top
    chopd top
    from Florida
    I bought one of those solid state deals on Ebay for $22.50 and figured I'd give it a try. I've got most of the wiring done on the car, just waiting on some new pigtails for the dash and I can get that wrapped up. It may be a week or so, but I WILL post some pictures of the results.
  8. Roadagent2
    Roadagent2
    EXCELLENT!!!!!!!- Montgomery Burns
  9. chopd top
    chopd top
    from Florida
    Here is the CVR that I got off Ebay
  10. chopd top
    chopd top
    from Florida
    This is where I mounted it. It comes with velcro backing and you can stick it just about anywhere.
  11. chopd top
    chopd top
    from Florida
    This is a shot of the back of the dash with it wired in. I've completed all the wiring in the car and everything works like a charm, except the two gauges that I have this thing wired to. I'm not writing this CVR off just yet, the gauges may have been toast before I started. I say that because almost all of the old wiring showed signs of burning. The jackets were dust and the wire itself was discolored. Oddly enough, the wires that DIDN'T show these signs were the horn wire and the turn signal harness on the column, both of which I kept.
  12. chopd top
    chopd top
    from Florida
    I'll try and update once I get the gauges out and tested.
  13. 1954vicky
    1954vicky
    from Reno, NV
    Any luck with the CVR? I've been looking at these on Ebay and would like to know how they work.
  14. chopd top
    chopd top
    from Florida
    No, nothing to report yet. I haven't had a chance to get the gauges tested.
  15. chopd top
    chopd top
    from Florida
    Update: My gauges are toast. I got 2 other sets only to find they are toast as well. I also found that my speedo is trashed. Since this is just a beater, I'm going to get some new gauges at the parts store and retro fit them into the dash. The CVR wasn't working but I did get one at the bone yard for $3 that works like a charm.
  16. 1954vicky
    1954vicky
    from Reno, NV
    Thanks for the update. I ended up getting one from Dennis Carpenter (part #D-10800) that works great.
  17. JeffB2
    JeffB2
    from Phoenix,AZ
    I heard that when you go from pos+ grd 6 volt to 12 volt- neg you should reverse the connections on the gauges,before you decided they were "toast" did you do that? Also could you check the voltage coming thru the CVR to make sure it is functioning.
  18. chopd top
    chopd top
    from Florida
    I heard the same thing, Jeff. I tried it (reversing the connections) but to no avail. Someone at some point in time had been in the gauges. The others that I got, looked about the same. I checked the CVR and nothing. It was supposed to be adjustable and still, nothing. Thats when I went to the bone yard and got one off a truck, tested it and found it was good. I went back and tested everything again with the new CVR and still, nothing. If it were something other than a daily beater, I would have a set of these rebuilt, but, it's a beater. :)
  19. JeffB2
    JeffB2
    from Phoenix,AZ
  20. JeffB2
    JeffB2
    from Phoenix,AZ
  21. chopd top
    chopd top
    from Florida
    Great stuff, Thanks Jeff!!
