insulation : how do you get the F off ?
Discussion in 'The Hokey Ass Message Board' started by rev. munster, Apr 20, 2010.
  1. rev. munster
    rev. munster
    from houston,tx
    Redoing the inside of my 54 and stuck on fightin the headliner insulation its caked on looks like stuck 50 yr old brownie ! Got s****ers but barely took anything off started using angle grinder with wire disk seems to make a **** stain smudge !
    Anyone have any advice or wisdom on how to get this tihs off !???
    Thanks
    Love the munster
  2. 40StudeDude
    40StudeDude
    Heat and s****e...that's the only way I know how to do it.
    BUT, why do you want to remove it...???
    R-
  3. Topless Ford
    Topless Ford
    Heat and s****e if you want it off....but..........on a hot summer day that is what gives off that wonderful asphalt old car smell!!!!!!
  4. Kensey
    Kensey
    from Pittsburgh
    Ha Ha! Totally been there. You need: several CD's, 6 of coldies, safety gl***es, metal s****er.
    Hint: keep the s****er clean...... cuts better.
    Have fun.
  5. Capt.Mike
    Capt.Mike
    My 40 Ford is the same way, the stuff is on there to stay. If it's on there good and strong leave it. It's still working and only needs to be added to to get the level of insulation you want. In this case the old saying is true "if it ain't broke don't fix it (or change it).
  6. If you do away with it be sure to put something else in it's place.
  7. Kona Cruisers
    Kona Cruisers
    snap on crudthug....
    bit spendy but way worth it!!!
  8. rev. munster
    rev. munster
    from houston,tx
    Kool beans !
    I wanna take it of cuz as I'm drivin around lil bits and pcs fly around get
    In my eys mouth ears just gets annoying drivin around with safty gl***e ear
    Plugs and half face respirator !
  9. rev. munster
    rev. munster
    from houston,tx
    Kool beans !
  10. Kona Cruisers
    Kona Cruisers
    **** your in Htown.... you have a compressor? ... ???
  11. rev. munster
    rev. munster
    from houston,tx
    No I'm in seabrook and no compressor !
  12. Black Primer
    Black Primer
    Sandblaster will take it right off.
