Technical Intake heat shield hitting road draft baffle
Discussion in 'Traditional Hot Rods' started by mullskull, Dec 29, 2024.
  1. mullskull
    mullskull
    I'm in the process of putting a factory dual quad set up off a 283 on a 327.. during the fit up a fitment issue revealed itself... it appears that the back of the heat shield is hitting the road draft baffle preventing the intake from seating.. it's about an 1/8 off.. all of the parts I'm using are original to the 327 which is a 1964 engine.
    I mean theoretically this intake should bolt right on right??? Were there variations with the road draft baffles, or are they all the same(283/327)
    I'm thinking that the heat shield needs to be trimmed a little, but i figured I'd check in with the peanut gallery before I start modifying anything...
    I've attached a photo showing where the shield is hitting.. the red is what I plan on cutting off- 20241229_201608.jpg 20241229_201608.jpg 20241229_201608.jpg 20241229_201738.jpg 20241229_201746.jpg
    Just Gary likes this.
  2. squirrel
    can you post a picture of the can installed in the engine?
    A chevy parts book printed in 1974 lists one part number for all 1955-64 engines for the can. Another Chevy book printed in 58 shows that same number for all small block V8s including Corvette, so it should be the same
    Truckdoctor Andy and mullskull like this.
  3. squirrel
    a few pics of how mine looks, 1962 327
  4. mullskull
    mullskull
    That's what I thought.. thanks for the verification , and the photos.. as far as I know these really only go on one way, right?
    Our photo look to be identical, no??
    Also, I've been running this engine with a offhauser intake /tri power set up with no fitment issues.
    I just dropped the original cast iron intake on the engine and it doesn't quite fit right.. but then again I removed the heat shield when I sand blasted it then welded it back on.. it should be in the right spot????
    Earlier I slathered the top of the breather with grease, when I dropped the DQ intake on the grease transferred over to that front part of the heat shield...
  5. I had the same problem on my 283 with a Edelbrock Streetmaster intake, my fix was to m***age the can carefully till there was clearance, have had no issues. JW
    RICH B, mullskull and SS327 like this.
  6. SS327
    SS327
    I’d just flatten the can before I cut the heat shield.
  7. RICH B
    RICH B
    I saw the baffle can was "squished" a bit on an old 327 I picked up, guy said it was done to fit an intake he used.
    26 T Ford RPU likes this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Too bad Jim’s engine is ****oned up. Both of you could have measured from China wall and compared.
  9. squirrel
    See if you can tap the can in further? loosen the screw first. It might let the bracket twist a little, and the added clearance should be all you need.
    just a guess, I can only look at pictures, I can't put my hands on it
  10. mullskull
    mullskull
    Funny you say that, cus I woke up this am thinking the same thing... it looks like your breather is in a little further-
    Thanks man, I'll keep ya posted!
  11. gary macdonald
    gary macdonald
    I just removed the 65 283 intake , i can measure mine if needed .
  12. mullskull
    mullskull
    I was able to knock the breather in a little bit and I also trimmed and bent the heat shield a smidge... she fit like a glove! 20250101_171321.jpg
    SS327, loudbang, RICH B and 7 others like this.
  13. tb33anda3rd
    tb33anda3rd
  14. mullskull
    mullskull
    Thanks!
  15. DDDenny
    Those are 1962/early 63 rockers covers, getting hard to find, did you have them chromed?
  16. mullskull
    mullskull
    Good eye.. most people don't even know the diffence! Yep, had them chromed... i also have a pair of factory chrome ones, but the chrome wasn't nice enough for the car...
  17. DDDenny
    Years ago I bought a pair of L79 rocker covers at the Portland Swap Meet that had been in a car that suffered a battery explosion, the original 350 hp decals were still in place.
    I thought they were subpar with the acid stains so sold them during a "housecleaning" session, wish I'd kept them for wall hangers.
