Technical Interesting Wheels Found, Any Ideas??
Discussion in 'The Hokey Ass Message Board' started by Joe DeBattista, Sep 23, 2022.
  1. Joe DeBattista
    Joe DeBattista
    6B219894-772F-409C-A261-75589487D166.jpeg 3B566017-66CD-4003-B8C7-0A9F29B59FB2.jpeg 63C4AAEA-0EAE-46AC-8A03-A26E2786FC24.jpeg I found these wheels at a buddy’s house and I could leave them I had to grab them. They are very interesting. 5 x 5-1/2 centers welded to 13” yea you read that right 13” hoops and chromed. What is the deal was this a thing? Or was this just some ******’s way of making “different” wheels? They are welded right up to the rear edge of the rim. Any knowledge on these is appreciated.
    fiftyv8 and hotrodjack33 like this.
  2. Homemade, for what purpose we can only guess at... although probably for a lowrider.
    fiftyv8, Joe DeBattista and 49ratfink like this.
  3. When I got my '34 basket case it had 15" centers welded into 14" hoops the same way.
    Joe DeBattista likes this.
  4. Joe DeBattista
    Joe DeBattista
    Low rider we thought that but the 5 on 5-1/2 center threw us. And the pinner white wall is in. I was thinking a rod someone wanted to show off their polished brakes. Lol fun to speculate
  5. Corn Fed
    Corn Fed
    If you had a pre 1948 Ford custom with skirts on it, some 13" on the rear would be an easy way to drop it down some. And if just a little of the chrome rim showed under the skirt nobody would be the wiser.
  6. In early Australian Hot Rodding it was common for rods to have 13" front wheels and 14" or 15" rear. Usually this was a way to lower cars as drop axles were uncommon.
  7. big duece
    big duece
    from kansas
    Looks like 49-50 Merc centers.
    downlojoe33 and deucemac like this.
  8. Left front or pony wheels for an oval track car?
    In the early days everyone was sure the left front wasn't doing anything and would often run a much narrower and small diameter tire on the left front and they often ran a lot of back set.
    Usually, using wide 5 center but 5 on 5" or 5 on 5 1/2" was not unheard of.
    upload_2022-9-24_16-48-3.png upload_2022-9-24_16-49-11.png upload_2022-9-24_16-52-46.png upload_2022-9-24_16-59-15.png
    Offset, perk03 and big duece like this.
  9. Might be a tight squeeze for a hubcap. :confused:
  10. Not just an Aussie thing. It was done a lot in the good ol' USA for drop and big n little stance. 13's were cheap and easy to get. Despite what the collected/selective memory around here says not everybody had the scratch for dropped axles/spindles, so being a hotrodder you did what you had to.
    Tman and Just Gary like this.
  11. 327Eric
    327Eric
    Shorter rim and tire to lower your final drive ratio for racing.
  12. hotrodjack33
    hotrodjack33
    My guess, considering there's 2 of them, someone with a Ford straight axle wanted the lightest front wheels possible. 0.28.jpg 0.29.jpg
  13. 14" rims, 15" centers.
  14. Marty Strode
    Marty Strode
    My first Hot Rod had 13's on the front, from a 63-64 Falcon, and 62 Fairlane as I remember. 2012-08-31 114836.jpg
    Tman, bchctybob, jimmy six and 3 others like this.
  15. Joe DeBattista
    Joe DeBattista
    I might look into getting them rechromed as wall hangers they are pretty neat pieces. Wish they could talk.
    fiftyv8 likes this.
  16. fiftyv8
    fiftyv8
    from CO & WA
    See if you can find some neat hubcaps to go with them...
  17. goldmountain
    goldmountain
    Getting them rechromed would be a problem. Most chrome reverse wheels have the center and rim plated first and then welded together with silver paint over the welds.
  18. These are the only 2 pics I have taken around February 1975 of my brothers 1936 Chev Panel Van on it way to its 1st Rod Run, the Chariots Stanwell Park Rod Run..........about 1 month later he I I attended the 2nd Australian Street Rod nats, me in my 1940 Dodge Sedan, Bruce in this 1936 Chev with the 16" rear wheels as pictured and a pair of 13 x 6" front wheels & tyres..........yep it sure had a rubber rake, also a Tatterfield triple carb intake on the stock 1936 engine, with 3 carbys tho' only the centre one was connnected..........had a slow but great trip to Naranderra from Sydney.......yep, back then we did whatever we could to be part of hot rodding...........Andy Douglas
  19. choptop40
    choptop40
    wall art...as is ..rust is a must...
  20. Beanscoot
    Beanscoot
    If you don't need the tires I can use them for my winter daily driver...
  21. Squablow
    Squablow
    New chrome would cost a fortune, but some wood bleach dissolved in a big plastic tub and soak for a few days would clean a lot of it off without hurting anything. That's one of the methods that guys use when they're trying to save chrome wire wheels without taking them all apart.
    Lone Star Mopar likes this.
  22. downlojoe33
    downlojoe33
    Some balled up aluminum foil and water and a lot of elbow grease does a pretty good job too.
  23. bchctybob
    bchctybob
    Yep, around my hometown there were cars that used 13 & 14” front wheels to enhance the “big n little” look. Those are unusual, if you bolted those to an old Ford drum the scrub radius would be comical.
    downlojoe33 likes this.
  24. stanlow69
    stanlow69
    @54delray
