Technical Intergrip/buttwelding clamps with a twist
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Nov 11, 2019.
  1. iwanaflattie
    iwanaflattie
    This may be a bad post
    Or it may help someone in a pinch...
    I have some intergrip or ****welding clamps from HF,like these:
    they seem to be ok for some ****welding but they **** when the seam is hard to reach and u cant get a clamp or a magnet etc....
    Im always dropping/losing the square rod,the tiny ****erly nuts or lock washer.
    This is what i came up with...easy, cheap and u can mess with how much tension u can apply by how big u make the wedge...
    The small relieve cut i made with my porta band saw and I cut the strap with sheet metal shears..
    Bent the strap with my vice..
    20191111_134510.jpg 20191111_134524.jpg 20191111_134627.jpg 20191111_134638.jpg 20191111_134646.jpg
    You can even add a little handle to the bottom strap so its easy to grab .
    I can make as many as i want and it only took about 2 mins per clamp...
    The strap is free,its the one the use to strap pallets together..
    I still gotta file sharp edges so i dont cut my fingers...
    Ok bye now
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    Good idea......I like good ideas, they make up for *my ideaso_O
    '51 Norm, neilswheels and VANDENPLAS like this.
  3. Greg Rogers
    Greg Rogers
  4. tb33anda3rd
    tb33anda3rd
  5. Mr48chev
    Slick idea, I'm wondering how the springs will deal with heat though.
    Stogy likes this.
  6. I like it. Well thought out.
  7. 41rodderz
    41rodderz
    from Oregon
    Good tech tip.
  8. chrisp
    chrisp
    Excellent idea.
  9. woodiewagon46
    woodiewagon46
    from New York
    You may want to contact a patent attorney!
    56don and kidcampbell71 like this.
  10. manyolcars
    manyolcars
  11. brEad
    brEad
    Maybe post this over on the homemade tools thread? Pretty nice!
  12. iwanaflattie
    iwanaflattie
    tb33anda3rd likes this.
  13. DesmoDog
    DesmoDog
    Too late. You need to apply for the patent before you publish details about it.
    kidcampbell71 likes this.
  14. bubba55
    bubba55
    Hey Bubba lykes 'dat
    Them's slicker than snot on a door knob
  15. alanp561
    alanp561
    If all you're doing is tacking between the temporary fasteners, it shouldn't be a problem at all. If you weld from spring to spring, that's a big weld to put on such light weight material and you might concentrate enough heat on the spring to damage it. Maybe?
    Mr48chev likes this.
  16. blowby
    blowby
    from Nicasio Ca
    Go on Shark Tank!
    Those HF clamps are fumbly little ******s alright.
    Good thinkin
  17. rusty rocket
    rusty rocket
    Nice! The power of the H.a.m.b. makes us better fabricators. Thanks for sharing.
  18. lippy
    lippy
    from Ks
    That's pretty neat, thanks! Lippy
  19. alchemy
    alchemy
    Very similar to the link above, but how about the bottom cross is made of some thick welding rod? You drill a hole in the upright strip instead of cutting a slot. Then the welding rod could either be a short piece that you don't mind losing on the floor, or a longer piece bent with a handle so you can grab it. The handle end could be two feet long if need be for a tight reach insertion.
  20. iwanaflattie
    iwanaflattie
    Yes...his clamps gave me the idea to use welding rod and im working on some that dont have the spring exposed...
    I like the welding rod idea because its less likely to go in your tire as a nail would...
    Thanks guys.
  21. Mr48chev
    I'm thinking that is a whole lot simpler to line those slots up when you are working blind rather than trying to hit a hole in the metal, at least it would be for me. I've got about 3 packs of the HF ones out on my welding cart and as Iwanaflttie said fiddle fumbling with those square pins is the big pain in the ****. cost wise the springs are going to cost as much or more than the HF units. which are 6.99 for a pack of 8 right now
    SKU 60545 for someone who needs the HF number.
    Now if we may ask, what is the size and source for the springs? At the local Ace they are going to be about a buck fifty or more each.
    The banding is easy to find if you look around where someone has been cutting it off and you local lumber yard probably has plenty that they cut off loads of lumber.
  22. iwanaflattie
    iwanaflattie
    I can get numbers when i get home but they were about 60c each at my Hardware store maybe cheapee on line
  23. alanp561
    alanp561
    The source of the springs could be something as simple as a handful of old used valve springs. Heck, I've got about 50 or 60 that I've taken out of rusty flatheads and saved in a coffee can for some reason. Maybe this is it?
  24. iwanaflattie
    iwanaflattie
    And theyare almost flat....they ave those end coils that sit flat
  25. Bugguts
    Bugguts
    Great idea. Everyone else already expressed my thoughts.
