Technical Interior Heat, exhaust wrap
Discussion in 'The Hokey Ass Message Board' started by Rice n Beans Garage, Jun 17, 2024.
  1. Rice n Beans Garage
    Rice n Beans Garage
    Wanted to see what you guys are using for muffler wrap? S/steel, fibergl***? Trying to reduce interior heat.
    Thank you for comments/opinions in Advance.
    Scott
  2. Exhaust/header wrap can trap moisture and lead to rust on steel, so be cautious. You'd be surprised what some thin aluminum heat shields spaced off the exhaust tubing can do for heat deflection. Also thermal insulation on underside of floor/firewall, as well as under the carpet will make a big difference.
  3. Rice n Beans Garage
    Rice n Beans Garage
    I have the floor and interior insulated, the mufflers are directly under the floor pan, (Model A Coupe), thank you for the suggestions.
  4. Unkl Ian
    Unkl Ian
    Put a heat shield on the floor. Wrap is fine for race cars that receive a lot of maintenance.
    '29 Gizmo likes this.
  5. Unkl Ian
    Unkl Ian
    The nascar guy use heat shield material developed by NASA.
    Look for used pieces.
  6. Bandit Billy
    Bandit Billy
    I wouldn't wrap the pipes. Summitt sells heat shield material you can apply under the car like they use on corvettes.
    Rice n Beans Garage likes this.
