Technical Interior panels
Discussion in 'Traditional Hot Rods' started by Bob Bagley, Nov 10, 2025.
  1. Bob Bagley
    Bob Bagley
    I need to make new door, kick and rear interior panels for my 40 Ford Coupe. Any suggestions on what backer board to use? Thanks!
    Just Gary likes this.
  2. Squablow
    Squablow
    I've tried several commercially-available backer boards for interior panels (like stuff that's common at home improvement stores) and I've never really been thrilled with it. A year ago I got a bunch of blank sheets from an auction of a closed upholstery shop and that's the stuff I want to use from now on but I don't know where to order it, I just got a pile of their leftovers.
    I'd also like to know where I can order bulk, blank sheets of door panel backer boards. The stuff I got was in a shipping box so they clearly ordered it from a supplier and had it shipped in but I don't think there was a label with the source on the box anymore.
    -Brent- likes this.
  3. RodStRace
    RodStRace
  4. Gold Top Gasser
    Gold Top Gasser
    I found a good product that you will find in the Lowes's cabinet idle. Its's a very hard but slightly flexible white plastic composite board. It's like masonite board but hard plastic. They use it to resurface old cabinets or something. I just found this stuff a few months ago by accident. Cuts easy with a jigsaw.
    mad mikey, bobss396 and Just Gary like this.
  5. 5window
    5window
    I like Sintra/PVC sheet, got it from a local sign shop as 1/8"x4'x8'. Waterproof, glueable with solvents or superglue and moldable with a hairdryer/heat gun.
    jaw22w likes this.
  6. '29 Gizmo
    '29 Gizmo
    from UK
    When I had my Roadster trimmed they used foamex board. Water proof, glue able, and can be be folded to some extent.
  7. Old Heap
    Old Heap
    I've used ABS plastic sheets in the past, 1/8". Keeps its shape has no fear of moisture. There's a local plastic supplier that sells 4x8 sheets for less than a hundred bucks.
  8. downlojoe33
    downlojoe33
  9. Bob Bagley
    Bob Bagley
    Thanks for the suggestions.
  10. Grumpy ole A
    Grumpy ole A
    I had a friend that was buying it from an upholstery shop.
  11. okiedokie
    okiedokie
    from Ok
    ABS plastic is what I used for my 40.
  12. kabinenroller
    kabinenroller
  13. 5window
    5window
  14. Squablow
    Squablow
    For the guys using plastic, are you able to sew through it? Or are you just strictly gluing material to it?
  15. Annette Chaplin
    Annette Chaplin
  16. atch
    atch
    Well, if 2.54 cm = 1" then 2.54 mm must = 1/10 " or 0.1".
  17. 01Jazz
    01Jazz
    I used the 1/8” plastic for headliner. Not s***ching through it…i glued the fabric over..
  18. 31 Coupe
    31 Coupe
    Has anyone used 1/8" (3mm) thick MDF board.
    My main concern would be its resistance, or lack of, to moisture (rain) sneaking down past the windows.
  19. saltflats
    saltflats
    from Missouri
    I wouldn't use that.
    Steve Reddy likes this.
  20. Annette Chaplin
    Annette Chaplin
    Thanks. Now, how close is this 1/10 or 0.1 to say, 1/64, 1/32, 1/16, 1/8, 3/16, 1/4? You know, the normal fractions that are printed on machinest scales, rulers, tape measures?
  21. 9200 IH
    9200 IH
    1/16" = .062 1/8" = .125
    5window likes this.
  22. atch
    atch
    @Annette Chaplin
    So I misunderstood your intent. I'm used to working in decimals and have scales, rulers, and tape measures printed in decimals. Here are some fractions (in 128ths of an inch from 1 to 20) and their decimal equivalents. As you can see 3/32" and 7/64" are the commonly used fractions that are closest to 0.10". Note that 13/128 is REALLY close but who can/would actually use 13/128?
    1/128 = 0.0078
    1/64" = 0.0156
    3/128 = 0.0234
    1/32 = 0.0313
    5/128 = 0.0391
    3/64 = 0.0469
    7/128 = 0.0547
    1/16 = 0.0625
    9/128 = 0.0703
    5/64 = 0.0781
    11/128 = 0.0859
    3/32 = 0.0938
    13/128 = 0.1016
    7/64 = 0.1094
    15/128 = 0.1172
    1/8 = 0.1250
    17/128 = 0.1328
    9/64 = 0.1406
    19/128 = 0.1484
    5/32 = 0.1563
  23. 5window
    5window
    Decimals are much more exact.
  24. 5window
    5window
    Only use MDF if you want to do the work over again in short order!
  25. Acres
    Acres
    from Sweden
    Back i the days it were called masonite, but now oil hardened board, i used that making doorpanels for my Chevy, easy too work with and it can handle some water
  26. Just Gary
    Just Gary
    4'x8' x 1/8" thick plastic-coated smooth white hardboard. About $19 at Home Depot and Lowe's.
    I covered it with black naugahyde that matched the seats.
    20250807_185656~2.jpg 20250807_205719~2.jpg 20250814_204025~2.jpg 20250814_205358~2.jpg 20250818_173118~2.jpg 20250821_205513.jpg 20250822_164610.jpg 20250822_202328.jpg 20250822_235859~2.jpg
    ottersea likes this.
  27. 325w
    325w
    Make it easy on yourself and use 1/8 inch PCV . Do it once and you’re done. Don’t even need a water barrier on the door. Easy to cut with box knife are saw.
  28. Steve Reddy
    Steve Reddy
    Don’t use it, if it gets damp it sags and gets waves in it. PVC. Or ABS
  29. 31 Coupe
    31 Coupe
    Thanks for all of the great recommendations.
    Though the MDF is ~10% of the price of the PVC, that becomes insignificant in the big picture when it all goes wrong.
  30. Annette Chaplin
    Annette Chaplin
    Ah, I see now sez the blind man. So that Miami Corp upholstery supplier, Cowlboard Waterproof OEM Natural is a, "whisker", or "two of those little marks" under a 1/8" (eighth of a inch). Good.
    Now if Miami Corp only stated so in their item description thickness. Look how much confusion would have been eliminated!
    Now the big question. Other than "kabinenroller" roller up there in the cold country. Has anyone else used this Miami Upholstery backing board?
    Thanks
