My green lens on my speedometer turn signal light has fell down, you can see about a third of it and the other 2/3’s is just the bare bulb causing a white light instead of green, does the chrome border by chance come out the front or do I need to pull the whole speedometer ***embly out to get to the lens ? Picture is just for reference, not mine
I know that the '54 Ford is pressed in from the front, I knocked the ring out from the back. Since the lens were brittle and broken I made 2 new replacements from a green plastic lid from from a container of sliced turkey. Everything put back together. HRP
HRP is spot on - the 55 jewels are the same, just knock them out from behind. https://www.hotrodreverend.com/post/2018/07/14/1955-ford-part-56-speedometer-and-odometer-reset
