Technical Intermittent squeak from flywheel area
Discussion in 'The Hokey Ass Message Board' started by Dooley, Apr 12, 2025.
  1. Dooley
    Dooley
    from Buffalo NY
    I am replacing my mini starter and I have an intermittent noise that sounds like a squeak or metal hitting the dust cover.
    The cover is off I'm just trying to describe the sound.
    Starter is shimmed 20250412_174754.jpg down and used both internal shims.
    Noise comes and goes esp when I hit the throttle. I've been under when its running and the starter gear looks just like it does in the pic. 20250412_174754.jpg
    Tow Truck Tom likes this.
  2. I had the same thing. After some Google searching, it seemed the most likely cause was a cracked flex plate. I removed the one from my car and ... yuppers, it was cracked (right near where it bolts to the crank). The cracks were extremely hard to see, even with it removed and in my hands so, if you remove yours, look VERY closely at it. I doubt you'll be able to see anything with the flex plate still in the car. I bought a new one rather than use any random old one I had laying about. Pain to change, didn't want to do it twice.
    I should add, my noise was definitely a squeak, it didn't sound like metal on metal.
  3. captaintaytay
    captaintaytay
    Your ***le says flywheel, is it a flywheel or flex plate as mentioned from "borntoloze"?
    If it's a flywheel then i'm ***uming it a manuel trans.
    Could it be a T.O. bearing making that noise?
    1940Willys and Tow Truck Tom like this.
  4. Dooley
    Dooley
    from Buffalo NY
    Flex plate. It’s an automatic
  5. 19Eddy30
    19Eddy30
    from VA
  6. I know this is straying just a bit from what the OP was asking but I had to laugh when you asked about a flywheel vs a flex plate. When I was looking for a flywheel for my 322 nailhead I had numerous, numerous people ask me if I was looking for a flywheel for an automatic transmission or a flywheel for a manual transmission..:eek:
    Larry
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Another Vote for Flex Plate
    gimpyshotrods likes this.
  8. Dooley
    Dooley
    from Buffalo NY
  9. captaintaytay
    captaintaytay
    Okay, now I would think it's a possible flex plate.:D
    gimpyshotrods and Dooley like this.
  10. guthriesmith
    guthriesmith
  11. Dooley
    Dooley
    from Buffalo NY
  12. justpassinthru
    justpassinthru
    Did it make noise before you changed the starter?
    Make sure the converter bolts are tight.
    Is there a lot of run out in the flexplate (wobble) while running?
    Push the crankshaft endplay forward and see if the ring gear gets too close to the starter.
    Could be the ring gear hits the starter gear drive under a load.
    If all that is is good, look for a cracked flexplate.
    Bill
  13. Dooley
    Dooley
    from Buffalo NY
    Noise started when I changed starters last summer.
    Changed to a new one this year because I borrowed one from Swade41.
    Made noise with both.
    Thought it was the dust cover but it's not
    I have a video of the car running and the fkex plate does not move.
    Sound goes away when under load.
    I was under the car when running and the fkex plate does not touch the starter gear.
    Converter bolts look good but I didn't wrench them I could try that.
  14. Dooley
    Dooley
    from Buffalo NY
    April 15, 2025
    here is a video same day without the noice..... it clears the starter gear.
  15. Dooley
    Dooley
    from Buffalo NY
    Well..started the journey to pull the motor.
    swade41 likes this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Isn’t it possible to remove the transmission? Or is there an x frame in the way? I have changed flex plates by sliding the trans back just a few inches
  17. 19Eddy30
    19Eddy30
    from VA
    @Dooley , Like @Moriarity said,
    Its slow & little of pain to do ,
    Use 2 ,,, 3 or 4 inch longer bolts as guide
    To hold transmission from falling / wedge sliding trains p*** dowel pins ,
    You can do with 1-1/2 gap between bell & block , More of gap makes it easier
    Some times you can do with out taken drive shaft out ,
    Tow Truck Tom and Moriarity like this.
  18. Dooley
    Dooley
    from Buffalo NY
    No way to remove the glide from the frame...I wish.
    Need to remove the grille and inner fenders as well as radiator. Then motor up and out
    Motor is too close to radiator and firewall
  19. 19Eddy30
    19Eddy30
    from VA
    All needed is to be able to slide transmission back from block about 2 inches
    No need to remove transmission from vehicle,
    If no room to do so , It sound like it was built with No wiggle room Close tolerances. Bummer to have to R& R engine ,
  20. Dooley
    Dooley
    from Buffalo NY
    No room at the Inn.
    Also need to change oil pan and gasket while out.
    winduptoy and Moriarity like this.
  21. winduptoy
    winduptoy
    squeeks usually happen in mouse motors
    alanp561, borntoloze and guthriesmith like this.
  22. Dooley
    Dooley
    from Buffalo NY
    Well engine is out and flexplate off and no crack.
    Thinking that the flexplate was intermittent hitting the starter gear.
    Need to clean and repaint the engine and change the pan.
    New flexplate ordered.
  23. willys36
    willys36
    Ain't hot roddin' fun?!!!!!!
  24. Dooley
    Dooley
    from Buffalo NY
    Think it's def the starter..i bought a 168 tooth flexplate thinking that's what I had but I had the 153.
    So for giggles I tried the bigger one because the starter works with both and still way to close 20250428_181926.jpg 20250428_181318.jpg 20250428_181312.jpg
    51 mercules likes this.
  25. Dooley
    Dooley
    from Buffalo NY
    Tried what I think is my new but stopped working jegs you can see the difference 20250428_184044.jpg
    captaintaytay and 51 mercules like this.
  26. Onemansjunk
    Onemansjunk
    from Modesto,CA
    9940D776-7B0C-4630-8E7C-49647A4560D6.jpeg Flex plate didn’t look like this AF235E89-7D98-45C5-8678-8AA92F52710A.jpeg
    Happydaze, SS327 and Tow Truck Tom like this.
  27. Dooley
    Dooley
    from Buffalo NY
  28. 19Eddy30
    19Eddy30
    from VA
    @Dooley
    The first pic does not look to been touching,
    The Jegs looks not to be engaging correct , Teeth to Teeth , & deep into teeth ,plus looks to have tips knocked off / chipped
    If bendex spring weak it will make a
    Digging noise bouncing off the flywheel Not a squeak,
    You can take starter (first pic ) mounting block off & add a shim ,
    My tilton is close like your first pic.
    The converter pad / hump ,
    Is it facing the converter, ? Hard to tell by picture.
    That looks to be a SFI Flex , hard to crack one under 500 tq ,
    Does welds look good No cracks,?
    Ring to Flex .
    Look & check bell of Transmission,
    When start to crack usually on the p***enger side /right
    when I install starter I snug bolts enough that I can pull Bendix out
    Into teeth on ring gear , ajust so no grabbing then lock bolts down .
  29. RMONTY
    RMONTY
    I had a flexplate do this running 70 mph down the highway in an OT Exploder. Talk about a weird feeling! The engine had trouble understanding what had happened with all the computer stuff checking this and that. It idled really crazy with no converter to push around.
  30. Dooley
    Dooley
    from Buffalo NY
    This is the jegs mini starter extended
    You can see the wear marks on the teeth of the old flexplate
    everything else looks good on it.
    The gold one in an earlier pic is new and never used.
