Technical internal vs external resistor
Discussion in 'Traditional Hot Rods' started by Douglas Smith, Aug 6, 2023.
  1. Douglas Smith
    Douglas Smith
    Any preferences on coils with internal resister vs coil requiring external resistor and a ballast resister for an inline flathead 6 cyl. 12V engine?
  2. KenC
    KenC
    I prefer the ballast with a ballast byp*** arrangement for starting. Helps in cold weather when starter draw causes the voltage to dip when cranking.
  3. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Consider this - resistors create heat. A lot of heat. Heat can destroy a coil. Coils get hot enough as it is and it doesn't make sense to me to add more. External resistors keep their heat to themselves and should not be mounted too close to the coil or flammable materials. A byp*** circuit is advisable, run off the starter circuit so it only comes into play while cranking. External, ballast resistor, same animal. :)
    Atwater Mike likes this.
  4. Truth be known, I doubt if any coil contains an internal resistor because of the heat issue. But there are coils wound with a higher internal resistance in the primary coil that don't require a ballast resistor. But using a ballast resistor with a lower resistance coil and the byp*** will give better starting performance.
    jaracer and 2OLD2FAST like this.
  5. '29 Gizmo
    '29 Gizmo
    from UK
    External. Keep the coil simple.
  6. PhilA
    PhilA
    Use what you can find easily at any big name parts store.
    No fun being stranded and not being able to source parts.
    I use a standard resistor, with the heatsink bolted to the firewall, and a basic coil from something GM mid 60's.
    (Got a spare in the trunk too).
    G-son likes this.
  7. I have always been a fan of simple and in this case that would mean a resistor coil. Now after saying that ,I just changed to an external resistor and the non resistor coil (with the byp*** when cranking) for easier faster starts. And I think it does start a little faster.
    So I guess simpler is not always better. Go with the external resistor with the byp***, you'll be glad you did.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Why is it that everyone ***umes that coil failure is a concern ? I don't recall coil failures or replacements being a common place occurrence . personally , in 60+ years working with ICE' s , I only recall replacing 1or 2 ! o_O
    G-son likes this.
  9. winduptoy
    winduptoy
    Run 6V and you don't need a resistor
    CSPIDY likes this.
  10. BamaMav
    BamaMav
    from Berry, AL
    I’ve ran both ways, never noticed any difference starting or while running.
  11. PhilA
    PhilA
    Just the same as with points, the quality of new ones just ain't there no more.
    302GMC likes this.
  12. I've been using the Bosch 12V Blue Coils on quite a few builds. They are internal 3.5-ohm resistance coils - have never had a bad one. They are typically about $40 - $60 on Amazon.
  13. No points is better!!:D:D
    Ben
    winduptoy likes this.
  14. winduptoy
    winduptoy
    Yes when it isn't polite to point....
    firstinsteele likes this.
  15. G-son
    G-son
    from Sweden
    Diesel engines solve a lot of problems. :D
  16. PhilA
    PhilA
    Compared to the $12 I paid for mine.
    Hence I keep a spare.
  17. Atwater Mike
    Atwater Mike
    Early Fords had ballast resistor under dash, drivers side. Pre-'46 they had that stamped steel resistor on top of the coil, at the front of the intake.
    Remove that resistor (either spot) and 2-3 days driving would boil the oil out of the Ford coil.
    But the engine sure had a hot spark for a couple of days! (Points didn't like it...)
  18. BamaMav
    BamaMav
    from Berry, AL
    I don't remember ever seen a resistor on a VW engine. As far as I know, they always ran an internal resistor coil. They made several million of them, so I haven't seen all of them, just a bunch...:D
  19. Mr48chev
    VW didn't go to 12 Volt until the 1967 year model. I had a friend with one that was early 60's in the mid 70's who had a fit because he couldn't install the 12 Volt 8 track player he had bought in it.
    Back to the original question, I always try to keep thing simple and there isn't anything much simpler than a standard 12 Volt coil and a ballast resistor and a resistor byp*** wire.
    It's not a good idea but if you do have a ballast resistor burn out you can usually get away with byp***ing it and driving to the closest place you can get one if you are on the road.
