Technical International frame swap
Discussion in 'The Hokey Ass Message Board' started by choppedrod63, Nov 29, 2015.
  1. choppedrod63
    choppedrod63
    I just found a nice early 50's International cab. Wondering what frame might be a god donor frame. There is nothing more than the cab. Thanks for the info.
  2. TLDLTD
    TLDLTD
    Early 50's International would fit best :)
    '48IHC likes this.
  3. Donald A. Smith
    Donald A. Smith
    from Brook In.
    Get some 2 x 4 1/4 wall steel tubing a straight axle a ford 9 in. rear end and build it your way! I will do this next time. Don in N. W. Indiana
  4. choppedrod63
    choppedrod63
    If I could find a frame that's what I would prefer to use. I don't have the space or equipment to jig up a frame right now. But thanks for the imputed guys
  5. Rusty O'Toole
    Rusty O'Toole
    Years ago a friend had a 54 International project and a 86 Chev pickup. He did some measuring and found the International was very close to fitting on the Chev frame. I don't remember the details, he may have had to change the body mounts but it wasn't very difficult.
    Usually on putting an old cab on a newer frame the big sticking place is the track width. The new suspension is a lot wider and sometimes the tires won't fit under the fenders.
    If you can find a pickup ch***is with the right track width and wheelbase you should be able to put the body on without too much trouble.
  6. Hnstray
    Hnstray
    from Quincy, IL
    Look to a more readily available GM or Ford Ch***is from the '50s - early '60s. That era
    ch***is is more like what was under the Binder originally (shape and size) and either can be
    readily upgraded with brakes, steering etc. As pointed out above, the late models are usually way too wide to readily adapt and look out of place.
    Ray
  7. rusty1
    rusty1
    ...got this one for sale, great body and complete frame, comes with a bed if needed,
    $1500 in northern Illinois.
