International Title Co
Discussion in 'The Hokey Ass Message Board' started by bustingear, Jun 26, 2008.
  1. bustingear
    bustingear
    has anyone delt with internatinal ***le Co. in Nevada? Are they legit?
  2. DKING
    DKING
    from LAS VEGAS
    Yes worth every penny.you should do a search.
  3. xix32
    xix32
    yes, had good luck. the do***ents i received worked for me in IL. last year
  4. 50dodge4x4
    50dodge4x4
    My son used them a couple months ago for a truck ***le here in IL. The paperwork went through the state without any issues. He recieved his IL ***le in his name yesterday. It works. Gene
  5. Robert gilbert
    Robert gilbert
    from boston
    how long did it take ????
  6. scootermcrad
    scootermcrad
    I had my Triumph paperwork done through them. Took a couple weeks to get the paperwork, but everything went fine.
    There's lots of good feedback on here about them. Never heard anything negative.
  7. rixrex
    rixrex
    worked for me..the best part about the deal is they use whatever VIN number you provide them, so your numbers match..I have used some of the others and yes, you do get a ***le with the correct make and model on the paperwork but the numbers will be from a vehicle that went to the s****per and they saved the ***le, then the numbers don't match..take the paperwork ITS sends you(usually Alabama) and do an out-of-state ***le transfer at your local DMV and you're done.....
  8. BobbyD
    BobbyD
    from Belmont NC
    Just did a '66 Sportster last week with them, got my paperwork in 8 days and it was a breeze at the SC DMV. Will be using them again......
  9. HOT ROD DAVE
    HOT ROD DAVE
    never used them, but have heard nothing but good things bot them
    will use them down the road i am sure, if i cant get it done my way first
  10. 50dodge4x4
    50dodge4x4
    I believe the entire process from start to new ***le in hand took about 2 months, but the truck was drivable at time of transfer, about a month into the process. Very smooth, quite fast, money well spent. Gene
