Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. 19Eddy30
    19Eddy30
    from VA
    First Time I meet Jonny was @ Carol Carter shop in Man***as ,late 80s , shortly after I way getting hand me downs ,My Father & I @ Goose Creek on the Mountain , Last time I seen the SWC Willys It was @ Dons in Fla on display & should still reside There ,
    Just Gary likes this.
  2. Just Gary
    Just Gary
    Speedo cable and gears using TCI's calculator.
    TCI Auto Speedometer Gear Calculator - TCI® Auto
    Use this TCI Auto Speedometer Gear Calculator Formula for any GM, Ford or Chrysler vehicle. This is very useful ...
    As a wiring virgin, it seemed prudent to pay for a few extra unused wires, instead of kludging together patchwork circuits.
    Following Jason's advice, I got Rebel Wire's 16 circuit universal harness.
    I minimized under-dash yoga contortions :p by first organizing bundles on the garage floor with bread bag ties.
    Then hanging the panel under the dash.
    Thanks to @squirrel & others for educating me on Mopar starter relays.:)
  3. Johnny99
    Johnny99
    Been following this one since you started. A really cool little hot rod and the orange a perfect choice! Nice job Gary.
  4. 19Eddy30
    19Eddy30
    from VA
    Gary , I was thinking if you where off to a exotic Place Hawaii, Fiji ,Caribbean,
    I guess Not , Just Exotic Fairfax,
    Im not a Mopar ,
    So does the Mopar starter relay Still Required /Needed in a Non OEM Circuit ?
  5. Just Gary
    Just Gary
    Dang.... I used to p*** C&C Automotive on #28 in Man***as while shuttling kids to soccer matches. :rolleyes:
    I knew they built all-aluminum 460+ inch Fords and should've stopped in, if only to leave a drool puddle.
    https://dragillustrated.com/carroll-carters-cc-motorsports-celebrates-50-years-in-business/
    Yes- some kind of relay is needed. I've learned Mopar's separate relay isn't subject to the heat soak/no-start issues like the integral Chevy design that I'm used to.
    Now time to go connect wires.:)
    brEad and lothiandon1940 like this.
  6. Just Gary
    Just Gary
    BLUF: The wiring kicked my ****. I couldn't have finished it without @squirrel 's @Dino 64 's and @oj 's help. Thanks, guys.
    Master disconnect in batt (+) cable, per NHRA guidance.
    A PS-64 oil pressure switch and backup toggle switch keep the electric fuel pump safe.
    This Carter P4070 pump only draws ~5 amps, so no relay.
    Engine:
    Ch***is:
    20241015_203353.jpg 20241018_171522~2.jpg 20241017_172849.jpg 20241027_140345.jpg
  7. Roothawg
    Roothawg
  8. The37Kid
    The37Kid
    Congratulations on the wiring, something I'll be avoiding.
    mad mikey and Just Gary like this.
  9. Dino 64
    Dino 64
    from Virginia
    Neat and tidy :) Almost ready for a shake down cruise :rolleyes:
  10. 19Eddy30
    19Eddy30
    from VA
    Gary , How close are you to getting rubber build up on the shiny Hugger inner Quarters ;)
  11. @Just Gary Thanks for the inspirational pictures!
  12. mad mikey
    mad mikey
    Beautiful job Gary. And , yea, I hate doing wiring. It always kicks my *** and gets me very frustrated.:(
    :mad:;):rolleyes:
    Just Gary and The37Kid like this.
  13. flamedabone
    flamedabone
    Man, this thing is SO close. Keep rolling, you are on the downhill slide.
    Nice work as always.
    -Abone.
  14. Just Gary
    Just Gary
    Soon; should prolly attach the doors first.:)
    BTW, the blue painter's tape labels remain until I'm confident everything works while driving.
    No A/C, heater or radio, but there is a Neutral Safety Switch:
    ...and a "Torque Converter Lockup Enable" switch.
    A 3rd brake light circuit remains unused for now; until I find a light that doesn't look ridiculous. Metro DC driving kinda requires one...:eek:
    Rebel Wire's headlight relays were out of stock, so I got one from Ron Francis.
    The MSD 6A ignition control box added unnecessary complexity :mad:, so I jettisoned it and bolted the ground bar in its mounting holes.
    20241103_163844.jpg 20241103_164843.jpg 20241103_164256.jpg 20241103_164634.jpg
    Finally, headlight, front TS, and horn wires sneak through tubes inside the frame's boxing plates.
    "Let there be light. ...... and it was good". Gen 1:3-4 (KJV).
  15. Tim
    Tim
    from KCMO
    Looks good! Where did you get the ground bar?
  16. swade41
    swade41
    from Buffalo,NY
    Getting closer !
    mad mikey likes this.
  17. swade41
    swade41
    from Buffalo,NY
    A friend of a friend has one of his cars, this guy has numerous high end cars in his collection in the Toronto area.
  18. 19Eddy30
    19Eddy30
    from VA
    Is the pic of Johnny's car recent?
    Rumored that the car went to Oz,
    That Pro mod should be the
    double railed car, with adjustment to
    to rails .The Last 33,
    I was @ Johnnys house
    When Merc was finished, picking up hand me down parts, Checking out Merc , Later
    I was inside car , The garage @ the main house, Johnny leaned in & asked if I would want & complete with one agreement that I would not run in Pro Mod cl*** , To many irons in fire @ the time .
    PS Glad to see car has not been destroyed /crashed and
    being preserved !!
    bchctybob, Just Gary and mad mikey like this.
  19. Just Gary
    Just Gary
    lothiandon1940, mad mikey and Tim like this.
  20. Tim
    Tim
    from KCMO
    Thanks
  21. mad mikey
    mad mikey
    Its absolutely A killer hot rod Gary.:) Can't wait to see you driving down the road, and some burn outs.;):)
  22. Just Gary
    Just Gary
  23. mad mikey
    mad mikey
    ^^^^PERFECT^^^^
    lothiandon1940, Dino 64 and Just Gary like this.
  24. fastcar1953
    fastcar1953
    Looking bad to the bone.
  25. Just Gary
    Just Gary
    "Precious bodily fluids":
    DOT3 brake fluid.
    Auto trans fluid.
    Motorcraft Friction Modifier Additive XL-3 & 80W-90 gear oil.
    bchctybob, catdad49, 69fury and 14 others like this.
  26. That friction modifier is a terrible smelling product
  27. Tim
    Tim
    from KCMO
    Getting close!
  28. Just Gary
    Just Gary
    Brake bleeding revealed a previous mistake. :oops:
    Remember my ginchy brake lines routed discreetly above the pedal bracket on the bare ch***is?
    Once the floorboards were welded in place, those fittings became inaccessible. And of course, they dripped DOT3.
    I reluctantly cut a small access hole in the floor to get a flare wrench on 'em.
    But had to enlarge it... Three times.
    Tightened 'em and finally got a hard pedal with no drips.
    Now to hang and latch the doors.:)
    bchctybob, catdad49, brEad and 14 others like this.
  29. Roothawg
    Roothawg
    Story of my life.
  30. Tim
    Tim
    from KCMO
    Ugh that’s frustrating. Keep at it man
