Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. Just Gary
    Just Gary
    "Jackandeuces" bent my spindles' steering arms & installed new bushings.
    I moved the steering box bracket to just aft of the motor mount. The drag link will angle back slightly but its well within P&J recommended tolerances.
    P&J tie rod, drag link and front panhard bar. The blue masking tape is supposed to protect the spiffy new chrome.
    My son and I ***embled the rearend with the stock F-150 11" brakes that he and I rebuilt, the diff that "Clutchdumpin Dan" and “BurnedOutOldMechanic” rebuilt, and shiny new 31-spline Moser axles. A skateboard makes a dandy rearend/ transmission dolly. :)
  2. Just Gary
    Just Gary
    Next was the P&J rear panhard bar. The AN fitting is the rear inside-the-frame brake line.
    Inspired by '60's G***ers' lead-filled pipe "bumpers" with screw-on end caps, I made one that’s similar, but simpler, from s****s. It's a thin-wall seamed 3" steel tube with 1/8" plate ends, all filed and sanded down to 400#. The plan is to get it chromed later, along with the front axle.
    "Dino64" provided a piece of 12"x12"x1/4" thick box, which I cut up for the bumper brackets. I'll drill some lightening holes in 'em when I get my own drill press.
    So far so good.:)
  3. Dino 64
    Dino 64
    from Virginia
    Wow, great work, making lots of progress [emoji106][emoji106].
    Go Matt, love to see father and son teams.
    Just Gary and lothiandon1940 like this.
  4. lothiandon1940
    lothiandon1940
  5. Dino 64
    Dino 64
    from Virginia
    Bumper came out great too, glad to see those big meats finally mounted. Look'in good [emoji41]
    lothiandon1940 likes this.
  6. neilswheels
    neilswheels
    from England
    This is great, definately gonna follow along. Re rear tyres, whay did you use to scrub of the lettering, and how did you finsh them? I never thought General Grabbers could look so good..
    Just Gary likes this.
  7. mad mikey
    mad mikey
    Great job guys, really like how this is coming together.:cool::D:D
    Dino 64 and lothiandon1940 like this.
  8. lothianwilly71
    lothianwilly71
    Nice work Doctor..
  9. Doctorterry
    Doctorterry
    One of my favorites... they just look so mean!!!
    "Keep on keepin' on"
    -Brent-, catdad49, mgtstumpy and 4 others like this.
  10. Dino 64
    Dino 64
    from Virginia
    You can use my drill press anytime
    lothiandon1940 and Just Gary like this.
  11. brEad
    brEad
    Glad this thread was brought back to the top or I'd have never seen it. Read the whole thing - cool build. I'll be following the rest of it.
    Dino 64 likes this.
  12. Just Gary
    Just Gary
    The Hemi has insufficient vacuum to support power brakes, so the master cylinder is a 7/8" bore, manual disc/drum unit from an '80 Mustang.
    Unfortunately, the through-the-frame- brake line stubs emerge where the master cylinder bracket typically goes. No problem- I lengthened the P&J bracket by 3.25" and OJ machined a longer & stronger pushrod. Together, they reposition the master cylinder farther aft, but keep the brake pedal right where it needs to be. Those two dark holes are through-the-frame tubing for electrical wires.
    Will probably add reinforcement bracing when finish-welding the frame.
    Mocked up driver's seat, steering column, brake & gas pedal. So far everything fits. Seats are MG Midget/AH Sprite (free off Craigslist) but may get replaced by more racy fibergl*** buckets.
  13. Just Gary
    Just Gary
    I'm gonna use a tiny alternator mounted low on the driver's side, so the stock crossover's alternator mount was an unnecessary wart. I whacked it off and filed the crossover 'til it looked right-- stockish but just a little leaner.
    Finally, front tires are Nankang 145/R15's mounted and speed-balanced on skinny 15"x3.5" Fenton Gyros. Can you say "under-steering pizza cutters"? :cool:
    Inner and outer sidewalls are ground and sanded smooth, just like the rears'.
    Joe Blow, -Brent-, mgtstumpy and 15 others like this.
  14. Dino 64
    Dino 64
    from Virginia
    Wow, way to go, made lots of progress this summer
  15. mad mikey
    mad mikey
    Wheels and rubber are really nice. They will look great on the car.:)
  16. Nailhead Jason
    Nailhead Jason
    @Just Gary
    Been wanting to do just this with the front tires on my 51. What grit/grit's of paper did you use? they look great!
    brEad likes this.
  17. Just Gary
    Just Gary
    Jason, here’s my tire sidewall smoothing process:
    • I practiced on the back sides of my wife’s minivan tires. :eek:
    • Like bodywork, use progressively finer grits but don’t transition to the next grit until ALL bigger scratches are COMPLETELY removed.
    • It’s much easier to smooth sidewalls when the tires are mounted & inflated. Protect the rim with a round piece of plywood.
    • Wear a dust mask to prevent black boogers and do it outside in direct sunlight. Use white chalk to mark where you started, outstanding flaws, etc.
    • For DOT inspection purposes, don’t remove tire size & DOT markings.
    • The skinny front tires’ sidewalls were far thinner than the big rear truck tires; so on the fronts, I skipped step 2.
    1. Flap wheel on Dremel to remove whiskers.
    2. #80 flap wheel on 4.5” grinder:
    a. Use the rounded edge to minimize gouges.
    b. Hold grinder flat against sidewall. Holding at an angle causes gouges.
    c. Let the grinder “float” over tire. Use multiple light p***es. Use your arms’ full extension.
    d. Continue until all letters & crosshatching are gone.
    3. #60 sandpaper on jitterbug:
    a. Remove all the gouges from the previous step.
    b. “Float” jitterbug over tire. Let it do the work. Use multiple light p***es.
    c. Continue until you have a consistent feather finish.
    4. #220 sandpaper on jitterbug:
    a. “Float” jitterbug over tire. Use multiple light p***es.
    b. Continue until consistent feather finish around entire tire.
    5. #400 wet sandpaper on jitterbug:
    a. Wet sand with water from an old Windex squirt bottle.
    b. “Float” jitterbug over tire. Use multiple light p***es.
    c. Continue until consistent feather finish around entire tire.
    6. Hand-held green scotchbrite
    a. Rub the entire sidewall- including remaining DOT markings- all the way to the rim. Continue until uniform finish on entire sidewall.
    7. Wipe down with tire dressing.
    a. Apply two coats and let them dry between coats.
    For more info, see “Drive’em’s” tech thread and another thread:
    https://www.jalopyjournal.com/forum/threads/smooth-blackwall-tire-sidewalls.378955/
    https://www.jalopyjournal.com/forum/threads/sanded-polished-tires.86131/
    And a 2009 Sport Truck article:
    http://www.trucktrend.com/how-to/wheels-tires/0703st-bfg-tire-sidewall-smoothing/
    Joe Blow, 4ever18, catdad49 and 6 others like this.
  18. Nailhead Jason
    Nailhead Jason
    Thanks! @Just Gary I have been wanting to do this to the Cooper tires on the front of my 51 since I put them on. They look like the should be on the front of a Honda not my Chevy. I think I will skip step 2 as well for the front tires on mine. Love how those turned out!
  19. 26hotrod
    26hotrod
    from landis n c
    JUST FOUND THIS THREAD AND AM I GLAD!! Thanks for posting all this info especially all the little details. Please keep us informed as this is really cool. Thanks again.........
  20. Just Gary
    Just Gary
    "Holy brackets, Batman!"
    20170930_135606-1-1-1.jpg 20170930_135849-1.jpg 20171003_220459-1-2.jpg 20170930_150128-1-1-2.jpg
    bchctybob, Joe Blow, -Brent- and 7 others like this.
  21. mad mikey
    mad mikey
    Nice work Gary.
  22. NashRodMan
    NashRodMan
    Yes, love the work you are doing on this car!!
  23. Dino 64
    Dino 64
    from Virginia
    Great work Gary, lookin good !
  24. 26hotrod
    26hotrod
    from landis n c
    Thanks for the updates and looking forward to the next post...........
  25. Deadbird
    Deadbird
    Looks great. Taking your time and doing it right.
  26. rawcjw19
    rawcjw19
  27. Just Gary
    Just Gary
    Hammer-Formed* Floorboards:
    I made a cardboard template of each floorboard piece, then a male buck from 1/2" MDF; slightly smaller than the final floorboard size to allow for flange thickness.
    ... and temporarily screwed & clamped 18 ga. sheet metal to the buck with a bit over 1/2" overlap on each side.
    The buck's slots are for my "caveman bead roller"; I pounded a 1/4" diameter steel rod against the metal above each slot until it deformed into a nice straight stiffening bead. :eek:
    ...then clamped each edge with an angle iron brace (an old bed frame) and gently pounded over a 90* flange.
    Finally, the flanges were trimmed and screw holes welded shut.
    I also made a simple flush access panel for the brake m/c.
    Right now, they're just press-fit into place. I'll plug-weld them to the existing subrails & cross-rails after all undercarriage work is complete.
    And yes, the engine & trans are mounted high in the ch***is, requiring a big trans /driveshaft tunnel.
    ____________________________________________________________
    *FULL DISCLOSURE*
    This unconventional method- using only hand tools in my garage- worked great for this project.
    But... For a second car or anything bigger or more complex, HAMBers like OJ or ClutchDumpinDan,
    using a bead roller & brake, could easily fab beautiful floors in a single afternoon,blindfolded and
    with one hand tied behind their back.
    Joe Blow, tomcat11, -Brent- and 13 others like this.
  28. Dino 64
    Dino 64
    from Virginia
    Wow !! Looks great. Done like a true hot rod by making the most of what you have on hand.
    Good to see it done by hand.
  29. Just Gary
    Just Gary
    Living & driving in metro DC, I compromised with front disc brakes. But if you squint your eyes, they kinda... sorta... almost... look like mid-'60's Hurst/Airhearts. ;) :rolleyes:
    My 17-year-old son helped install 'em & pack the front wheel bearings.
    "Long shank" lug nuts.
    Next on the list: Fuel tank.
  30. mad mikey
    mad mikey
    Fantastic Gary. I like the way you did the floor. Shows thinking outside the box, and figuring out how to make it happen with what is on hand. Car is turning out great. You and your son should be very proud.:)
