Projects Introducing the Roofus Special
Discussion in 'The Hokey Ass Message Board' started by Flipper, Mar 1, 2009.
  1. Yes, build control arms like on the 1930's Miller Indy cars
    87 vote(s)
    67.4%
  2. No, go with a Ford style straight axle
    42 vote(s)
    32.6%
  1. Ned Ludd
    Ned Ludd
    I think the 87/88 aspect ratio was the unstated default under previous versions of the metric tyre-size system. I recall being told that the first Firestone "wide-oval" tyres were 82% AR and later ones 78% - both distinctly tall profiles by today's standards.
    Duallies on hillclimbers were often the same size as the front tyres. (That means 50- or 45-series tyres on the back and conventional period tyres on the front might look right - if you squint :)) Another thing one did see during that era was "fats and skinnies" with the same overall diameter, something like the traditional approach to custom bike wheels and tyres. There are many examples on the Specials thread.
  2. Flipper
    Flipper
    from Kentucky
    All of that tropical moisture pumped in by the former hurricane made it difficult to get interested in doing anything in the shop. I did get the outdoor pics though.
  3. Ned Ludd
    Ned Ludd
    Here's a quick sketch, based on one of those side views:
    There are a few tweaks: taller wheels - I've taken the liberty of showing the special-style "fats and skinnies" I mentioned earlier; grille shell moved back and given a visible radiator cap; hood extended into the cowl area; "door" cut-outs reprofiled a bit; cycle mudguards; aero screens. What do you think, Flipper?
    ratrodrodder likes this.
  4. James D
    James D
    I like that a lot! Looks just like it should.
  5. xderelict
    xderelict
    And a little angle from under the rear axel to the tail. A line from under the axel vertically, to the tail at the axel line horizontally. Just a little lift in the tail.
  6. charleyw
    charleyw
    It also seems that the sketch has a shorter "rear wheel to end of boattail ratio". I like it.
  7. Ned Ludd
    Ned Ludd
    That's an unintended consequence of drawing a circle with a comp*** instead of constructing a near-circular ellipse for the rear wheel. The rear wheel ends up ever so slightly longer horizontally than is geometrically correct. The intention with the sketch is to see what overall proportions end up doing rather than to represent the car photo-realistically. On top of that the overall diameter of the tyre is greater than in the photos, so the rear edge will be further back, and the cycle mudguards read as part of their bulk.
    The taller tyres and mudguards will tend to balance the visual m*** of the tail better, without any changes to wheelbase and/or rear overhang.
  8. plym_46
    plym_46
    from central NY
    I think a bit of an arch on the body panel from the rear wheel to the tail would look good, but it looks like you would need to modify your frame to accomplish that. Looks pretty good just sitting there. Where does the body sit in relation to p***enger height. Looks like the seat position might have the body up under your arm or at neck level which might call for some triming.
  9. Flipper
    Flipper
    from Kentucky
    In the latest mock-up configuration, the driver's arm and shoulder are outside the body at times. The shape of the cut out allows plenty of clearance.
  10. farna
    farna
    That's why some of those old racers made similar to your car had sort of thick padded upholstery wrapping around the cutout to the outside of the car -- for an arm rest.
    Definitely angle the bottom of the tail at least from the back of the rear wheel up about 6-8". If not you will end up dragging the tail at times.
  11. Flipper
    Flipper
    from Kentucky
    My plan for dragging involves a wheel back there.
  12. farna
    farna
    And when you pull the rear wheels off the ground? Well, the suspension should have a bit of down travel, but you have a frame rail running under the axle, so it could happen. I hope you're not serious with the little caster.... better run something like a go-cart rubber tire. I think you'll need it unless you just stick to major streets. I'd kick it up at least a few inches, but it's your ride!
  13. dad-bud
    dad-bud
    Hi Flipper,
    Well, it's taken me a few evenings now to get through every post in your thread - phew!!!
    I'm blown away at your inventiveness - turning random pieces of metal into a brilliant rendition of a boattail speedster.
    It looks like you've already got lots of suggestions about what you should do with your special - I think Dawie's sketch with the shorter boattail looks better, it will help with approach angles as well though I understand it's mucho work to unpick what you have, but I think it will be worth the effort - you can rejig the clearance around the rear axle to get the ride height too.
    Anyway, enough about my $0.02 worth - please keep posting your progress and good luck with finishing it as soon as you can (while fiting it in around your life too)
    Cheers.
  14. Ned Ludd
    Ned Ludd
    As I said above, I haven't shortened the tail. It's exactly as Flipper has it; it's just the taller wheels that make it look shorter.
  15. Flipper
    Flipper
    from Kentucky
    I think he used this angle for the sketch.
  16. Ned Ludd
    Ned Ludd
    Correct.
  17. woodbutcher
    woodbutcher
    :D:eek: Hi Flipper.Looking GOOD.Love the build.Keep up the good work.
    Good luck.Have fun.Be safe.
    Leo
  18. Flipper
    Flipper
    from Kentucky
    My little car needs wheels and tires along the lines of this sweet little car! ...maybe a tad smaller on the rear.
  19. farna
    farna
    The wheels, yes, but I'd still go with same size tires all around -- between the two sizes shown in the previous post would be about right. Just my opinion is all!
  20. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Hey! I made those wheels!
    Jimmy
  21. Flipper
    Flipper
    from Kentucky
    He told me you made them. He said you were also working on something special for his coupe.
    If this thing turns out to be worthy of cool wheels. I will probably be giving you a call.
  22. Flipper
    Flipper
    from Kentucky
    Cooler weather is just around the corner...maybe I can get something worthwhile done on this thing soon.
  23. Flipper
    Flipper
    from Kentucky
    Heading to Dad's house this weekend. High temps are supposed to be in the low 60's :)
  24. dad-bud
    dad-bud
    Keep up the good work Flipper, make sure you keep posting updates and lots of pics please.
    Cheers.
  25. Flipper
    Flipper
    from Kentucky
    I stripped it down (body panels off and engine and trans removed) and rolled it on its side so I could weld up the bottom seams.
    I love the fish shape that the body has
    After I was done welding, I put the motor back.
    I really need to figure out floor supports. It needs to connect the front inner frame to the rear inner frame AND put some structure under the area that I will stand on when I step into the car (in front of the seat).
  26. Flipper
    Flipper
    from Kentucky
    Oh yeah. I picked up a few needed parts at a swap meet. ...shackles for the front spring and cool little old tractor headlights that will be converted to tail lights.
  27. ..never noticed the beautiful fish-shape of the frame until you showed it from underneath, very nice! and congrats on your swapmeet finds, let's see 'em! good luck, always good to see some progress, this will be a unique beauty, that's fer sure!
  28. Cabbie
    Cabbie
    from DeLand, FL
    Just curious how you are going to register this car? Also, how does the insurance company come up with a value on this car if it ever gets totaled, or stolen?
  29. Flipper
    Flipper
    from Kentucky
    At this point, I'm not sure if it will ever make it past garage art / big go-kart status. It has taken a lot longer than I ever thought it would. ....but I am enjoying the hell out of the project.
    I love the shape and imagine it will be so much better with cool engine noises to match the looks. I can't help but thinking I really wouldn't want to wreck it /get run over by a SUV.
  30. Rickabilly
    Rickabilly
    Don't worry Flipper, speaking as a long time sports car guy, when/if you do ever get it on the road, you'll find that you are so much more agile than anything else on the road that avoiding SUVs will be a lot easier than you can imagine.
    I used to live in Australia, my fear was three and four trailer 120 tonne roadtrains while I was driving in 900lb spaceframe cars. Just try overtaking a 120 tonne 150 foot long vehicle with 58 wheels all kicking gravel up on country roads when you don't even have a windscreen. Best invest in some goggles.
    Rick
