Iron Duke Motor
Discussion in 'The Hokey Ass Message Board' started by MERCURYGUY, Feb 4, 2011.
  1. MERCURYGUY
    MERCURYGUY
    Iron Duke Motor - Anyone out there used this motor ? I have heard there are concerns about using this motor do to primarily marine use. I was going to try and locate a Chevy II 4 banger but a lead came up on a Iron Duke Motor Any suggestions guys ? Thanks Tom
  2. Moon4975
    Moon4975
    from Texas
    I aways thought the chevy 2 four banger was the iron duke motor, I have been wrong before.
  3. wickedgoodracer
    wickedgoodracer
    s10 duke is the best 'cause u can get 4spd 5spd and od automatic,the marine intake is good but the cam ,not so much
  4. wickedgoodracer
    wickedgoodracer
    chevy II motor 62 -65 duke 80 -88 years are aproxamate
  5. chuckles0
    chuckles0
    Do a search on here for iron duke. There are alot of build and link notes. The marine cam can be a good cheap cam and performs better than the stock. Lots of after market parts and cams. Can build good intakes and exh. The pistons are the same as a 327 chev. I raced a Monza w/ a 2.5 chev 2 /mercuiser eng. in mini-stock cl*** that did very well. The crossflow head is much better. The bigger 3.L uses the head from a 460 ford. . Lot and lots of info and builds !!! SEARCH
  6. Which Mercruiser head (2.5, etc) fits the early Chevy II engine and which cam should I look for?
  7. five or six cars around here runnin them,They seem to power the track tees ok and the guys get killer mileage,not bad since most have small gas tanks,guys are runnin PGs to 700r4s so cant go wrong one even has a set of S&S harley carbs on it....
  8. Rcraft
    Rcraft
    from cypress tx
    i have one out a pontiac but has coil packs. what do i do for ign.
  9. 1934coupe
    1934coupe
    I had a 1970 4 banger in my Willys I think last year for the 4 in Nova. Great engine I would do it all over again in a heart beat. Use the later Iron Duke plenty of speed parts right from GM including block
  10. BobPer
    BobPer
    Tom, This may sound nuts, but I have a brand new Iron Duke short block from the early 80's that is still strapped to a pallet at my Dad's (I swear I store too much stuff at my Dads). I didn't use it in my T because I didn't have the ****** for it, or any wireing. Bob (P.S. Did you get the magazine I sent?)
  11. gtkane
    gtkane
    If you want a cheap powertrain, stop by my shop with a truck and a bottle of Jack, and I'll help you load up this...
  12. Fast67VelleN2O
    Fast67VelleN2O
    Here is one that I picked up this past summer at a swap meet. Algon injected, roller valvetrain, Mexican head and block, ported, etc.
  13. CutawayAl
    CutawayAl
    from MI
    Those engines were made in at least two different configurations. They are fairly light for an all iron engine. Some had balance shafts. I believe they were all 2.5L. In normal use they have a good track record. Like the earlier Chevy II engine, they were successfully used in midgets. GM even offered heavy duty parts, and a kit that allowed the engine to be laid almost on it's side for use in midgets. If you try to get a a lot of power out of one the strength and stiffness of the block is marginal. Worst case the block cracks in half near the middle. The cam has only three bearings so with really radical cams flexing of the cam is a problem. At one time GM offered a stronger race block that had 5 cam bearings. If I remember correctly GM also offered a race head for the engine. I know of one in a road race car that was stroked to 3.1L. There wasn't room for adequately sized crankshaft counterweights and even the addition of mallory metal didn't make them heavy enough. Although it made good power, as a result of the counterweight issue it was unreliable due to repeated breaking of the best high quality billet crankshafts.
  14. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    The chevy II four banger was made up to at least 1970. One place to find them besides in chevy II's is in the '68 to '70 DJ-5A Postal jeep where they were mated to a powerglide. Here's a pic of the engine bay of a '70 DJ-5 I picked up recently. Just bought it for the motor.
  15. bulletproof1
    bulletproof1
    from tulsa okla
    as just stated,,the iron duke was used in jeeps....lots of aftermarket parts ....lots of torque ....
  16. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I wasnt refering to the Chevy 4 banger as the Iron Duke although many call it that. The real Iron Duke is a Pontiac 151 4 banger. It has a cross flow head and doesnt share any parts with the Chevy. It was made from '77 to '93.
  17. Bama Jama
    Bama Jama
    Iron duke was used in a number of cars in the 80s. The crossflow head was introduced in 79. It was used by AMC,Jeep,as well as GM in Sunbirds,Monzas,S-10s and I think Camaros in the early 80s.It was fuel injected and called a Tech IV in 82, used in front drive apps and the Fiero. I had one in an 80 Sunbird that had 150,000mi on it and still ran great. The car had 30,000mi when I bought it. The engine far outlasted the rest of the car.
