irragation motors
Discussion in 'The Hokey Ass Message Board' started by Bart78, Jan 23, 2012.
  1. You guys obviously haven't ever heard of the "Red-Ram 392"
  2. 29AVEE8
    29AVEE8
    Nearly all of the old wind machines in the orange groves in Redlands, Highland, Riverside area were flathead Fords. I have one, with the ch***is (it makes a cool test run stand). They used a toploader three speed coupled to the prop mechanism.
  3. Back in 2000 we were out in Colorado, at an old gold mine at Cripple Creek that was made into a tourist site, and the elevator motor that took us down inside the mine and back up was an old Chrysler hemi. I took a picture of it at the time, but don't know what happened to the photo.
  4. 32coupedeville
    32coupedeville
    from cincy
    been there done that and it was awsome .it is cool to say you went into a gold mine and a hemi toook you there. here are some pics
  5. 32coupedeville
    32coupedeville
    from cincy
    any more pics of these industrial engine?
  6. straightaxle65
    straightaxle65
    Never say Never...........There were indeed 392 Industrial Hemi's. There is an airaid siren at Don Garlits Museum with a 392 for Power. Chrysler, more than anyone, was in the business to sell product. If they could build it they would sell it.
  7. Orchard air sprayers also used industial engines from different manufacturers. I've seen 4 cyl flathead Willys to diesel John Deere over many years, and maybe a gas IH or two.
    Always know your surroundings...........
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
  9. vrod64
    vrod64
    from Katy,Texas
    Correct...most I have seen in Texas are 331 Industrial. They actually run "backwards" on irrigation pumps ......some internals will have to be changed.
    Most were set to run at 2650 RPM on larger 8" pumps.
    My 2 cents
  10. TR Waters
    TR Waters
    from Vermont
    One last time. There were no 392 hemis built for industrial applications. This is not to say that somewhere, at sometime, someone didnt swap out a true industrial for a 392 car engine.
    And industrial engines did not have any longer stroke than their car. truck. or marine counterpart. Sorry, its just not true.
  11. TR Waters
    TR Waters
    from Vermont
    more industrials
  12. 32coupedeville
    32coupedeville
    from cincy
    tr waters nice find. would like to here two hemi's running together with duals on a pump.
  13. denis4x4
    denis4x4
    from Colorado
    Petronix, formally the Per-Lux Ignitor was originally developed to replace points for continous running engines in 24/7 situations.
  14. stuart in mn
    stuart in mn
    This is a little Onan generator that uses a flathead Ford for power. It's still in use, in a small town municipal pump house.
  15. Truckedup
    Truckedup
    Running a gasoline engine to pump water has to be expensive, but farming is what it is.
    True story of two vintage aircraft builders driving through Oklahoma and hear off in the distance the sound of a V-12.Some searching and find a WW2 vintage Allison 1710 engine running huge pumps.Considering gas engines under load use about 1/2 a gallon per hour per HP,that a lot of ****ing fuel.
    I've seen all sorts of old gas engines running industrial generators from Y Block Fords to 12 cylinder Cat Diesels.Many now use gas turbines (like a helicopter engine) because they can be made to burn cheaper fuels.
    Sometimes the engines are changed on a regular basis as a maintenance program for back up generators.Saw a pair of 454 Chevys than ran on natural gas for short money.Natural gas fired engines are down rated on power compared to gasoline ,moderate RPM's, were in fine shape.Two bolt mains,cast cranks,forged 8.5 pistons.
  16. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I used to work at a machine shop in west texas. We rebuilt some Irrigation well motors. Most were 455 olds. Once we went out to a big alfalfa farm to pick up an olds motor to rebuild and under a lean to on a big barn was about 20 retired hemi well motors. Would have been nice to have had the forethought and resources to buy them up and store them for 40 years. They more than likely all went to s****.
  17. 55chevr
    55chevr
    I repaired the oil pan on a Chrysler Hemi engine that was the emergency engine for a chair lift on a ski hill. In the event of an electric power failure the hemi was used to bring the people down ... there was a flathead Ford engine in the other lift ... the owner owner wasnt interested in up grading to a modern V8 ...
  18. George
    George
    So Don never had a spare 392 to drop into a favored project....
  19. stuart in mn
    stuart in mn
  20. stainlesssteelrat
    stainlesssteelrat
    from ms
    i wonder how that siren would sound like with a blown hemi 426 in it?
    hmmm
  21. TR Waters
    TR Waters
    from Vermont
    What about 4? :D
  22. Vergil
    Vergil
    One of my 8ba's, this was from the Las Angeles area ran on propane in a orchard on a big fan. The valve chest was clean with no sludge.
    Vergil
  23. bulletproof1
    bulletproof1
    from tulsa okla
    i have a 331 industrial hemi .. was used for pumping water on pecan farm, ran on propane....still has the paint on the valve springs.... it was a one owner... low hours super clean,,,,
    the industrail hemi motors have a different timing cover and freeze plugs i think the crank snout is also a little different as well... Hot Heads offer all the parts to convert it over . alot of these had adjustable rocker arms as well...
  24. TR Waters
    TR Waters
    from Vermont
    Sort of off topic from irrigation engines, but this is one of my favorites.
  25. Not true.
    EVERY SINGLE industrial I have seen firsthand (more than a dozen so far and ALL were tagged by Chrysler as an industrial engine) used the same timing cover, crankshaft, block, etc as p***enger car engines. NOT a single one of them had adjustable rocker arms either. Just because the covers could accept them does not mean that the factory therefore had to put them in. When you truly understand how a manufacturer's engineering changes, production, and cost saving measures all work, then it all makes sense.
  26. I've seen other references to air raid sirens using a 392 besides the Garlits one.
    You can say never, but remember back then if you had the money and said "I want this" and the company had it to sell you, or could build it off the shelf? You'd get it.
  27. George
    George
    That may be true, but it is still a car engine diverted into something else, not a purpose built Ind. engine.
  28. czuch
    czuch
    from vail az
    Great informative thread.
    I'd looooove to have that sno-mobile. But I dont wanna live anywhere snow.
  29. 39 All Ford
    39 All Ford
    from Benton AR
    I grew up around pump motors. The farmers where I lived used a variety of engines, sometimes their choice was made for durability reasons, sometimes the choice was made for economic reasons, and the depth and volume of the water was a big consideration as well.
    I have seen everything from an Isuzu diesel from a Chevrolet Luv, to big *** diesels.
    Those pumping from shallow 8" wells were likely to make an economic purchase. Most were V-8s converted to natural gas. The brand of engines bought new tended to change with who sold the most economical (cheapest) engines at the particular time the farmer needed the engine. For a time Chrysler industrial ruled, then Ford industrial, and then when big block Chevy crate motors got dirt cheap, that is what was mostly used.
    Diesel motors converted to natural gas were very popular also. ***mins 855s were popular as well as Caterpillars for the high end pumps.
    Farmers were adept at using what was available, they would often take inline 6s and V-8s out of cars and trucks. They would all last pretty well so long as hardened valve seats were in place to deal with valve recess caused by running on natural gas.
    Every pump I ever saw was designed to turn at 1720 RPM. The engines were connected to a "gear head" via a driveshaft that was about 4' long. The "gearhead" converted the the horizontal rotation of the driveshaft to vertical rotation via a ring and pinion. The gear ratio of the ring and pinion determined the RPM at which the pump engine would operate.
    (as a side note, the pump, called bolls, or bowls, were down in the water, connected to the gearhead by a driveshaft 100', 200' 300' or even 600' long. The driveshaft ran in WOODEN bushings, lubricated by "turbine oil" set on a slow constant drip, thus it was important NOT to overspeed the pump, lest you burn out the bushings. )
    Anyway, for the folks who were pumping deep and/or 12", 14" or bigger wells, big engines were the rule. Some would even run a TANDEM gearhead, with one Chrysler hemi on each side of the gearhead. The "second engine" would in fact run backward, but all of the other pump motors I have seen were standard rotation.
    The RPMs the engines ran varied depending on the gearhead used. For example, we had an 855 ***mins that ran with a 4 to 5 overdrive gearhead, meaning that this engine ran at about 1,370 RPM. Another well we had ran a BBC (and at one time an IH V-8, 406?,) it was set up with a 5 to 4 ratio, this engine ran at about 2,150 rpm.
    The gearhead ratios and capacity varied quite a bit, as did the engines used.
    There were local shops that would add to the mix of engines a lot.
    It was not uncommon to start a pump and not shut it down for 3 or 4 MONTHS. The ones that ran natural gas burned super clean, and the oil would last a season. Typically, we were getting 3 or 4 years out of the V-8s before rebuild or replacement, and 10 + years out of the converted diesels.
    Typically, (in my experience) the wear that would knock these engines out of service (the V-8s anyway) was valve recession, even with hardened seats. Seldom did one of these engine die by virtue of catastrophic failure, cylinder, and/or bearing wear.
    Another interesting point is that I would only see one of these pumps with a radiator every once in a blue moon. These engines typically incorporated a heat exchanger built into the pump output. This is pertinent because these engines would often live their whole life without experiencing a single overheat situation, might make a difference with a flathead....
