Is a 396 crank the same as a 427?
Discussion in 'The Hokey Ass Message Board' started by tjet, Dec 12, 2013.
  1. tjet
    tjet
    Looking to build a 427 BBC. Want to know if I can use a 396 crank for it. Thanks
  2. arkiehotrods
    arkiehotrods
    Yes. Same stroke.
  3. ssaza25
    ssaza25
    from arizona
    Can use a 366 or 396 crank in a 427.
  4. GOSFAST
    GOSFAST
    Only physically the same, there were different shafts for different HP ratings.
    The low-perf 396's had cast cranks, the hi-perf 396's had steel (#6223). The low-perf 427"s had steel (#6223), but the hi-perf 427's with the large rod bolts had "heavier" shafts (#7115). These were cross-drilled as well.
    Many of these steel's (mostly in the hi-perf builds) were "Nitrided" from the factory.
    Thanks, Gary in N.Y.
    P.S. There were other forging numbers available but these were the most popular. They were all balanced for their respective applications. The 7115 shafts had more material in the counterweights to make up for the heavier rods/pistons.
  5. tjet
    tjet
    Are the 6223 cranks cross drilled?
  6. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    I do not think that the 396(6223) were cross drilled from the factory. Around here to have one Nitrided is around $100.00
  7. falcongeorge
    falcongeorge
    from BC
    yes and no. GOSFAST is on the right track, if you run stock replacement 427 pistons or pistons that weigh close to the same), it will need a slug of mallory metal to balance.
  8. tjet
    tjet
    How much did it cost to get yours done with the mallory & ballanced?
  9. falcongeorge
    falcongeorge
    from BC
    It wasn't mine, it was for a motor I built for a guy, and to be honest, I cant remember. It was about 15 years ago anyway, so it wouldn't help much. It only took one piece, and we used brand-new TRW L2268's so that should tell how long ago it was! ;):D
  10. arkiehotrods
    arkiehotrods
    From chevellestuff.net
    396/402/427 - 1965 through 1972
    The 396 crankshaft is the same as the 427 crankshaft except it is lighter due to the counterweight design. The third counterweight on a 396 crankshaft is 3/4" wide, the 402 is 7/16" wide, and the 427 is 7/8" wide.
    Prior to 1968 all 396 crankshafts were forged steel. In 1969 the lower horsepower engines used a cast iron crankshaft.
    All 1965-1967 427 crankshafts were forged steel. For 1968 & 1969, only high performance 427s used a forged steel crankshaft where low performance 427s used a cast iron crankshaft.
    From mortec.com
    BBC Two-Piece Rear Main Oil Seals
    3.76" STROKE (used on '65-'90 Mark IV 366T, 396, 402, 427 or 427T)
    6223.......396,402,427...forged, 1053 steel
    7115.......396,402,427...forged, nitrided, cross-drilled, 5140 steel
    3804816....396,402,427...cast
    3856223....396...forged
    3863114....402...
    3863144....396,402...
    3874874....396,402...
    3879621....427...forged
    3882841....396...forged, cross drilled, nitrided
    3882842....427...forged, cross drilled, nitrided
    3882847....
    3882848....
    3882849....427...forged
    3887114....396...forged, nitrided, 5140 steel
    3904815....396,402...cast, nodular iron
    3941180....
    3942411....
    3965746..........semi finished, forged
    3993804..........raw, 5140 steel
    My first car 40 years ago, was a '66 Chevy with a 325 horse 396. It had a forged crank (and was the first engine I ever rebuilt)
