Technical Is anyone still using 4 speed transmissions?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 13, 2017.
  1. DDDenny
    NEVER!!!
  2. is that "reverse lockout" really a 3 speed shifter w/ sep reverse rod? I ask, because back in the day, we used to do that, 3 speed shifters were cheap and in our budget.
  3. deathrowdave
    deathrowdave
    from NKy
    My old tank Harley is a 4 speed , hand jammer , and my Power Wagon is a 4 speed . As I have said in the past FE Ford with Big Spline Top Loader = BIG FUN
  4. LOL my 355 starts running about 3K and will happily run @ that RPM all day and has for 150Kplus.
    My only problem with a standard is that sometimes I get lazy and don't feel like rowing the gears. On those days I am less of a hotrodder and more of a boat person I suppose. :D
  5. Gman0046
    Gman0046
    P&B, all SBC's run great at 3000 rpm and run all day with no problems. I just don't want to be running close to 4000 rpm's just to keep up with traffic for 10 hours when I drive the 650 miles to our beach house in Florida. I'd much rather see 2000-2100 rpm on my tach then close to 4000 at 80-85 mph. I sure don't complain about the gas milage either. If someone wants to crank the **** out of engine just to keep up with traffic thats their business. I just don't choose to do it because theres no reason for it. Back in the day everyone wanted a 4:11 or 4:56 rear end but we didn't go anywhere on Interstate Highways because there were none. We mostly stayed in our own area.
    Gary
  6. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Upgraded my Pontiac from an auto to a HD 3spd and a 3.64 rear. I love the gear noise. I'm sure a 5spd would drive nicely, but it would take a lot of the character out of the car.
    Sent from my ONEPLUS A3000 using The H.A.M.B. mobile app
    '51 Norm likes this.
  7. Not sure about his--- but the Hurst shifter in my '64 Malibu (mounted to an m-20 Muncie) has a flat red T handle that's a reverse lockout. Looks a bit different than this pic though. Can't remember the model name/number but I went to buy one for the wag a couple years ago and found that it was discontinued.
  8. bobss396
    bobss396
    I run around 3200 @ 70 with the new 3.89 rear, not bad at all. Definitely nicer around town picking up some RPMs with the steep-ish cam.
    jeffd1988 likes this.
  9. Correct in your reasoning. Depending on the gear of course. I had a 3.08 in the Pusher and @ my 3K to 3200 sweet spot I was cruising @ 80 mph. Now with the engine in the raven's roadster and the deep gears it is only running @65 at that RPM.
    A lot of your choices on RPM and Cruising depends on the build. An extreme example would be the Boss 302 that we had when we were kids. 3K would have been lugging the motor, it started climbing upon the cam @ 4K. But on the other end of the spectrum a stock low output 283 would be real happy running @ 2K. I seldom disagree with you and I am not now, your logic is always good, I think that it is just that we are shooting at a moving target here.
    firstinsteele likes this.
  10. 550Coupe
    550Coupe
    My 41' Ford convertible runs a 324" Olds w/ Ford top loader four speed with Jeep shifter. IMG_0816_2.JPG
  11. hendelec
    hendelec
    His 57 Chevy had a Muncie FOR YEARS............not 57 years.......... ;-)
  12. Flat Six Fix
    Flat Six Fix
    T98 acme in 55 fargo, soon to be replaced with A833 Overdrive 4 spd......A833 bullet proof tough especially the older cast iron cased units for hemis...
    fourspeedwagon likes this.
  13. gimpyshotrods
    gimpyshotrods
    I found a company that makes a push-pull setup for my favorite transmission.
    On my next build, I am going to have six-on-the-tree.
  14. Oh my God that 41 look awesome- the 4 speed is icing on the frosting on the cake.
    Yes, that not so common a833 variant with overdrive is one I'm looking for for my Sub'.
  15. Jalopy Joker
    Jalopy Joker
    the right trans with a hydraulic clutch hooked to the right motor and rearend can be a real joy - had a OT ('66) Ford Fairlane with a mildly warmed up 390 with hydraulic clutch hooked to close ratio top loader 4-speed back to a 9" rear with 2:75, or so, tall gears (never checked actual ratio) - slug from stop sign but, on freeway at 70mph shift down into second gear from fourth and was like hitting a nitrous bottle - lots of highway fun
  16. wojojo
    wojojo
    OEM 4 speed in my OT '67 bug. '53 Plymouth 3 on the tree. Love the sound of 2nd gear.
  17. 31hotrodguy
    31hotrodguy
    Thanks for clearing that up. Apparently it wasn't that obvious. [emoji3]
    Sent from my SM-G550T using The H.A.M.B. mobile app
  18. FNG
    FNG
    from New Jersey
    Part of my plan for my 48 Plymouth regardless of weather I keep the Chevy 6 or go small block Chevy for several reason seems everyone and his brother runs an automatic for the obvious reasons its easier, well I say they're equal, you need to run cooling lines and a trans cooler with a 4 speed you need to run clutch linkage but with hydraulic clutch set ups its not all that hard. For me I have two other reasons A; because I'm cheap:) and already have everything I need and B: my wife won't be able to drive it :D:D:D
  19. Fatbrosracing
    Fatbrosracing
    from Australia
    IMG_7027.JPG IMG_2256.jpg Two, Muncie with a Vertical Gate shift in my '39 and a Muncie for the '32 with an old swap meet shift, the number on the stick says it's from a Hurst Olds, I don't know how that ended up in Australia
  20. John Starr
    John Starr
    What a great thread.
    My street-bike days left me addicted to manual shifting.
    I hate mush-o-matics, even in my commuter car -- got a five speed in that grocery-getter. My wife was scared sh*tless to learn stick, but once she did... she could not be stopped. She went out of her way to rent a five-speed turbocharged Citroen during our Honeymoon in France -- and insisted on doing all the driving.
    If/when I get another hot rod, it would ideally be a manual 5 speed -- four for fun, fifth for freeway.
  21. Ebbspeed
    Ebbspeed
    I have a cast iron A833od in my 38 Dodge coupe, with a Hurst shifter. It's a fun ride.
  22. bchrismer
    bchrismer
    Danny, I went one less when I pulled the 350 turbo out of my '40 coupe, and put a Saginaw 3 line 3 speed in it. The 2.79 rear gears love the 3.50 first gear. I considered using a 4 speed on the column, with a separate reverse lever, but chose to keep it simple.
  23. ModelAPunk
    ModelAPunk
    from Buffalo NY
    I'm running a T-10 4 speed in my 53 Chevy with a 327 under the hood. Absolutely Love it! It Makes driving the car even more fun! Still a work in progress...
  24. jeffd1988
    jeffd1988
    Overdrive is the norm now to keep up on highways. Cali 80mph is the norm believe it or not I'm actually seeing semi trucks at 65 now here and sometimes in the 3 Lane over p***ing wich there not supposed to.
    I did a 5 speed for traveling. So I can hear my wife and kid as well when speaking. and if alone hear my radio.
    My truck had a 4 SPD but since it was a truck style trans I only used 3 gears out of 4.
  25. Gman0046
    Gman0046
    jeffd1988, definitely the way go. I always build to match the vehicles planned usage.
    Gary
  26. Digger427
    Digger427
    Anyone know a good source for replacement gears for a BW T 10?
  27. Schwanke Engines
    Schwanke Engines
    We have Zumbrota bearing and gear here in MN they are decent.
    Sent from my XT1585 using The H.A.M.B. mobile app
  28. wicarnut
    wicarnut
    I guess I'm the odd duck again, NO shifters for me, have an OT Camaro ragtop I purchased new w/ a 5 speed and will never change it. Have not had shifter vehicles since 1970 w/ exception of my OT and motorcycles.
  29. butchcoat1969
    butchcoat1969
    4 speed? I am but I call I a 700R4 3 forward and 1 overdrive gives me a 4 speed lolololol seriously I do have a Muncie with hurst shifter I put in and take out about once a year so I have the both or 2 worlds lol
    Sent from my iPad using The H.A.M.B. mobile app HotRod Harry
  30. badvolvo
    badvolvo
    I have a Muncie in my 59 vette, it was in there when I got the car, correct one would be a T10. 355 gears, don't need an OD in to run 80+ all day. I need to pull it out, replace the syncros and re-bush the shifter, not looking forward to it but it must be done before the HAMB Drags! Works fine under 5000 rpm, but hard to get into 4th when shes wound up. Not easy to adjust the shifter when the trans is in. It's been about 40 years since I tore into a Muncie, any suggestions on mods or tips would be appreciated, although I expect there is lots of good info somewhere on the hamb.
