is bigger better?
Discussion in 'The Hokey Ass Message Board' started by polish54, May 6, 2009.
  1. polish54
    polish54
    from flint
    so whats everyone think about,widening the rear fenders on a 54 chevy truck to fit some bigger whells and tires just because i got a good deal on them? it only needs a 1"? worth it? or just trade the wheels and tires to a friend for posiiable the right ones? {mans those 17"smoothis sure look cool!! haha} just a polish guy looking for feed back!! thanks!
  2. Rich Rogers
    Rich Rogers
    If you're only going to gain 1 inch I don't think it's worth it. You might be able to put fatter tires under it by increasing your back space on the wheels. Measure the depth from the inside of the tire to the spring and compare that to what's available and go from there.
  3. Mr48chev
    In the 70's that was the standard thing to do to get fat tires to clear as very few people thought to narrow an axle. Depending on what rear end you have you might be better off finding a rear end that is a couple of inches narrower. No body work and it should only take a few hours to do.
  4. polish54
    polish54
    from flint
    its a s10 ch***is with a blazer rearend so just bolts in nice and easy!
  5. Retro Jim
    Retro Jim
    I would change the rims or just get a skinner tire . The back space works the easiest if you want wide tires . Try a Camaro rear .
  6. Shifty Shifterton
    Shifty Shifterton
    Personally, that's the kind of detail that makes a vehicle for me. Everyone else says "only an inch", I say the mark of a well done modification is you can hardly tell. Good luck!
