Is it a 30 or a 31?
Discussion in 'The Hokey Ass Message Board' started by mod700rmk, Jan 25, 2009.
  1. mod700rmk
    mod700rmk
    from WA State
    Can anybody tell me if this is a 30 or is it a 31 coupe from this picture?
    I am saving the money to buy the car and just wondering what year it actually is.
    Donation welcome....
  2. r8odecay
    r8odecay
    So, where is it?
  3. the radiator shell and splash aprons are `30
    who know what happened to it in the last 79 years
    DylanHill1931 likes this.
  4. kieran
    kieran
    from San Diego
    if it has a stock grill shell, its a 30, cause the 31's had a painted upper grill
    check out this link for more info- http://www.mafca.com/whatyear.html
    ps great find
  5. poorboy
    poorboy
  6. mod700rmk
    mod700rmk
    from WA State
    Thank you, this is a really good link.
  7. DrJ
    DrJ
    Those two together say '30.
    The two piece aprons (see the split at front edge of the running board) would require removing the body from the frame to change so they probably haven't been changed
  8. HELLMET
    HELLMET
    looks to be a 31
  9. v8ford
    v8ford
    look at the firewall
    see if it has a teardrop "late 31"
    if u can lift the body
    bout where the front of the cowl is
    back of the motor mounts
    clean it up for the number..
  10. i'm curious , how did you come to that conclusion?
  11. 63dan63
    63dan63
    Early '31s had a '30 style grill shell. Henry used them until they were gone. Then switched to the '31 style shell. The late '31s had a dimple in the firewall. The motor is probably not original. The only way to know for sure it to find the serial number on the frame.
    Great find. Good to see that they are still out there hiding in the weeds.
  12. -Brent-
    -Brent-
    Does it matter?;)
  13. 32SEDAN
    32SEDAN
    Man that is a score. Get it before I do! I think I know where that yard is... :)
  14. Toast
    Toast
    from Jenks, OK
    Ditto;)
  15. The37Kid
    The37Kid
    What do you guys do to the photo to allow you to see if the splash aprons are 30 or 31, black blob on my computor.
  16. bruce hylton
    bruce hylton
    from toledo wa
    Fill hole of radiator looks like no threads(31). Good after market eyes help to beat the band.
  17. 325w
    325w
    Will this be c***ified as a barn find yard find field find hill find under tree find ??????????
  18. wbrw32
    wbrw32
    Exactly my thoughts too
  19. HotRod33
    HotRod33
    does it really matter.....? Hell half of the guys on here would buy it in a heart beat....doesn't matter what year it is.....
  20. Deuce Daddy Don
    Deuce Daddy Don
    I would say 1931---SS strip around cowl, like my old 1931 pickup in 1959.
  21. To enlarge the picture left double click on the picture. If you still can't see it well enough you have other problems.
    Charlie Stephens
  22. coupeHEAD
    coupeHEAD
    From the grille shell and the splash aprons it is almost certain to be a '30. A dead sure way to tell is to look under the dash on the firewall and see if there are rectangular support brackets for the radiator support arms. 30's didn't have these and Henry added them in 1931. And for the record the stainless cowl band was on both years.
  23. kenagain
    kenagain
    from so cal
    blow it up to 400% n ya can see the line straight down from the backside of the cowl runs thru the apron 1 year only definately 1930 aprons
  24. If you want to buy it, why does it matter? Buy it and the paperwork should tell you. Needs the same amount of work eiter way, and you can build it to the same car from either year. Parts are available for both, mostly interchageable.
  25. mod700rmk
    mod700rmk
    from WA State
    Does not matter in the least, I have always wanted a 30 or a 31 A coupe and never cared which one it was. I was just wondering because I never was quite sure how to tell them apart.
    This one will be in my shop soon, 30 or 31.
  26. HELLMET
    HELLMET
    i was going by the ss strip . billy
  27. fab32
    fab32
    Post some pictures when you get it in your shop. The experts will have some other views to reference.
    Frank
  28. The37Kid
    The37Kid
    Yes, it gets larger but the darkness stays the same.
  29. 63Compact
    63Compact
    I got a 29 open cowl in the shed at my folks place with a stainless band..
    From the grille I say 30.
  30. skuzkitty
    skuzkitty
    If you plan on chopping,channeling or any other kool ideas I wouldn't think that was an issue.
