Is it necessary to bottom master?
Discussion in 'The Hokey Ass Message Board' started by Hellbentrodder, Sep 3, 2012.
  1. Bentrodder
    Bentrodder
    from Cotati
    Hey HAMBers I have a question that I searched for but can not find a real answer too. I am building a '28 tudor on a '32 frame. I made my own brake pedal with a 6.5:1 ratio with an under floor master. My question is should the pedal be able to bottom out the master dry before hitting the floor boards? I have been told it should for those "oh ****, no fluid " situations, and then I have been told is does not need too. Please help?
  2. ironpile
    ironpile
    Let it stop a 1/2 inch from the floor,that way you will get the most brake action if fluid is low.
  3. vintagedream
    vintagedream
    I've always understood it is necessary for it to bottom out before the pedal hits the floor. That's what I've done with my present project. Remember to allow for future carpet if it's not installed yet.
  4. Bentrodder
    Bentrodder
    from Cotati
    Thanks for the quick answers. I knew I could count on the HAMB!
  5. auto shop
    auto shop
    from kentucky
    If you push the piston all the way in it can ruining the master. It normally states in the bleeding direction,
