Is a Muncie the right (ie best) gearbox to use for a 60's styled rod? One has come up for sale with no bellhousing or shifter.
Sure...Muncies were around from at least the mid-late 60s...with Saginaws before that. If you're runnin' a Chevy motor, it'd be a natural choice.
Thats great thanks. My list of things to buy is growing. Gearbox - Muncie Engine - Early SBC (although I'd love a hemi) Ch***is - Custom made bare 27 T frame Body - Hopefully the steel 27 coupe with the roof cut off thats for sale Wheels - Radirs or ARE's or similar Front end - MorDrop on hairpins rear end - early 9 inch, 12 bolt GM or late 50's early 60's olds Thats the list so far, only a few more things to think of like brakes, and steering
If you are bucks-down, the Saginaw four speed is worth a look. The ones out of Vegas have a wide-ratio ge****t that gives a lot of dig in the lower gears, even with a highway-ratio rear gear. On a street-driven hot rod, that is a valuable compromise.
Here's a link to Hack's old thread on the Saginaw ******... lotsa good reading. http://www.jalopyjournal.com/ubbthreads/showflat.php?Cat=&Board=UBB1&Number=161958&page=&view=&sb=5&o=&fpart=all&vc=1 Ed
