Is kickdown needed
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Jul 2, 2009.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Is kickdown needed th 350 olds trans.I want to run tripoer
  2. captain scarlet
    captain scarlet
    from Detroit
    I think so or you will burn out the clutches.
  3. kraka138
    kraka138
    if you plan on p***ing...or accelerating at speed.....but if you're running a manual valve body you should be able to get away without
  4. Rust Monkey
    Rust Monkey
    Yes, unless like the Captin said you want to burn up your clutch packs.
  5. scottybaccus
    scottybaccus
    I don't know where the idea of burning clutches comes from. TH350 kick down just forces a down shift. It's not like a 700R4 where line pressure is controlled, so far as I know.
    You won't like p***ing without it, but as stated, a manual or semi-manual valve body calibration will allow you to downshift with the stick, at will.
  6. squirrel
    Not needed, but good to have. Trans will last longer and work better with it. You'll probably have more fun driving with kickdown also...
  7. kraka138
    kraka138
    i didnt get why people were saying that either, like you said the worst thing would be no accelerating once to speed (not quickly anyway)
  8. MikeRose
    MikeRose
    from Yuma, AZ
    With a good shifter, you can easily down shift safely when needed.
  9. Rust Monkey
    Rust Monkey
    I know, on power-glides and chrysler 727's the kick down linkage also holds line pressue during acceleration to time your up-shifts correctly too. Is this not true of a TH350 or TH400? The concerns for clutch damage stem from not haveing the kick down to do this function.
  10. 325w
    325w
    Don't they shift before they should. Seems the one I ran for awhile without the cable shifted real quick into third. ???????
  11. You will need the vacuum line to the line pressure ac***ulator on the back of the valve body. Otherwise it will snap your neck on upshifts (unless you like that sort of thing...lol) no matter what the speed.
    On mopar autos, the kickdown controls everything. learned that lesson the hard way.
  12. squirrel
    That's true for the most part...but in a 350 when the detent forces a downshift, it also increases modulator pressure which increases line pressure by way of the main pressure regulator valve.
    The 350 will live quite a long time without the cable connected...but a 700 wil fry pretty darn quick!
  13. I don't have mine hooked up yet, shifts normally, if I need that oomph, I just downshift manually...
  14. carcrazyjohn
    carcrazyjohn
    from trevose pa
    The only reason Im asking is because I want to run Tripower .I personally would like to leave it hooked up,I dont want. to buy speedways base plates.Linkages will be on same side Causing the kickdown dilemna,
  15. MikeRose
    MikeRose
    from Yuma, AZ
    I ran a TH350 for years without a kick down. That was in a trans with a shift kit, and that I drove HARD daily. I bought an old holley double pumper that didn't have have the linkage on it, and I was too cheap to buy a new base plate (and the old linkage was nicer than the new stuff). It's a lot nicer to have the kick down for every day driving, but it will live with out it. If you don't downshift manually it will feel sluggish when trying to p*** in third. Upshifts will be as they are with kickdown. If you don't have a decent shifter, you might over shift into 1st or Neutral.
  16. dickster27
    dickster27
    from Texas
    What's the issue with running a kick down on your turbo with tri power? If it's a 2G, you already have a spot on the
    throttle arm to install it. If you have a 94 or a stromberg setup you can simply use the right linkage arm with extension below the throttle shaft ( which if you have either you probably already have one, just make sure you know that one pulls from the top and one pulls from the bottom) and there you have it. Not rocket science, nor do you need to have or get anything "hi tech" to make it work. Just remember, "neccesity is the mother of invention".
  17. bobwop
    bobwop
    from Arley, AL
    ****, you are the carby GOD! Say hello to your lovely wife for me
