Technical Is Lithium Grease Compatible with Silicone Rubber?
Discussion in 'The Hokey Ass Message Board' started by 5window, Jun 5, 2023.
  1. 5window
    5window
    Okay, this hopefully is simple. I need to replace some radiator hose couplings. The new ones are made of silicone rubber. Can I use White Lithium Grease to ease them onto the metal outlets without affecting the rubber? Thanks.
  2. onetrickpony
    onetrickpony
    from Texas
    I would use silicone grease but I've never seen lithium hurt rubber.
  3. BJR
    BJR
    IS LITHIUM GREASE COMPATIBLE WITH SILICONE RUBBER?
    Not if it's used for bigger ***s! :p
    SS327, caseywheels and alanp561 like this.
  4. Blues4U
    Blues4U
    from So Cal
    Lithium is just the type of thickener used to hold the oil in suspension to form the grease. Any danger to the silicone rubber would come from the petroleum oil in the grease, not from the lithium thickener (A typical grease consists of about 80 - 90% oil). However, according to this chart, silicone rubber has good resistance to mineral oils, so I wouldn't think it would be a problem.
    https://goodyearrubberproducts.com/...log4888/ParkerSiliconeCatalog48881.Page29.pdf
    5window and Truckdoctor Andy like this.
  5. da34guy
    da34guy
    I always spray my hoses with carb cleaner and they slide right on. No messy grease to worry about
    BJR likes this.
  6. '29 Gizmo
    '29 Gizmo
    from UK
    Dont use anything that remains in place like grease or oil. Lube silicone (and any other rubber) hoses with liquid soap.
  7. patterg2003
    patterg2003
    I have used dish soap on stubborn things. It is harmless on most things.
    Davesblue50 and Truckdoctor Andy like this.
  8. lostone
    lostone
    from kansas
    +1 dawn dish washing soap...
  9. I use Dawn dish detergent at work.
    Davesblue50 likes this.
  10. lippy
    lippy
    from Ks
    I use dawn makes my hands soft. It aint as good as palmolive but.....At least that's what Madge said.
    SS327 and Davesblue50 like this.
  11. 5window
    5window
