Technical Is "Metal Rescue" the same as "Evapo Rust"?
Discussion in 'The Hokey Ass Message Board' started by tubman, Feb 24, 2015.
  1. tubman
    tubman
    I'm full of questions today! I brought a 4GC with me to the Keys this winter to rebuild so it will be ready to go when I get back to Minnesota. I am dis***embling it, and realize that I would really like to soak some parts in Evapo Rust (which has always worked very well for me). The only store of any consequence anywhere near me is a Home Depot. They have something called "Metal Rescue" that sure sounds like Evapo Rust. Anyone have any experience with this stuff?
  2. HOTRODPRIMER
    HOTRODPRIMER
    What is a 4GC? HRP
  3. Saxman
    Saxman
    Danny - It's the GM Rochester 4-bbl prior to the Q-jet. Standard equipment on a lot of 50s and 60s GM 4-bbl applications.
  4. Check with some of the boat shops down there, they will have what you need.
  5. tubman
    tubman
    Anybody have the answer to this specific question?
  6. OzyRodder
    OzyRodder
    Yes it is the same but I have had better results with metal rescue.
  7. Mark T
    Mark T
    So what are they? Citric acid?
  8. tubman
    tubman
    They work by a chemical process called "Chelation". I looked it up in the internet and got fully confused. I believe that a Mol***es/water solution works by the same process. All I know is it doesn't damage anything and works great (expensive, though). I'll get some Metal Rescue today and see how it works.
  9. Texas Webb
    Texas Webb
    Be sure and let us know how it does.
  10. Beau
    Beau
    I just use vinegar. I have been cleaning up lathe parts all week. It works great.
  11. tubman
    tubman
    Here are a couple of before and after pictures of the 4GC carb base I did in "Metal Restore".I soaked it in carb cleaner for a day and washed it off before letting it sit overnight in "Metal Restore". You will notice that I left all the carb linkage on it. That was because the secondary shaft was frozen in the body and wouldn't move. After the soak, it was freed up completely. It appears to be the same stuff as "Evaporust", but I can't rate the performance because I couldn't use the two side by side. I was satisfied with the performance, but not the price ($25/Gallon).
    Before :
    After :
  12. tubman
    tubman
    I have used vinegar with some success too. I prefer this type of product because it will absolutely not harm anything other than rust. You can forget something soaking in it for a week, and nothing else will have been affected. Last year I had a '50 Ford grill that I wanted to sell. It looked pretty good, but the backside was really rusty. I soaked it in "Evaporust" and it removed all of the rust from the backside. It left the chrome completely intact, and the amazing part is that the remnant of the factory black paint in the grooves in the grill extensions wasn't even touched.
    Vinegar and citric acid are just that, acid. While they work, you've got to watch the process carefully if you don't want damage something. Lots cheaper, though.
  13. 69thumper
    69thumper
    i use metal rescue to clean out motorcycle gas tanks all the time, works great. wouldn't leave it in more then abt. 12 hours. good luck!
  14. jimcolwell
    jimcolwell
    from Amarillo
    I use SC1000 remanufactured in Abilene, Tx. Search SC1000 on the internet.
  15. tubman
    tubman
    I "Googled" "SC1000" and got a bunch of electronic gear, a dress, and a couple of lamps? Are you sure that's the right name? I'd sure like to find a cheaper alternative!
  16. jimcolwell
    jimcolwell
    from Amarillo
    Sorry, orisonmarketing.com/sc1000
  17. tubman
    tubman
    Clicked on your link and got an immediate "404" error (Not found). Before we get too involved in chasing this down, is it much cheaper than the other products?
  18. patmanta
    patmanta
    from Woburn, MA
    Now there's apparently a WD40 product in the mix out there too.
  19. tubman
    tubman
    Even more expensive at $28.50 a gallon. Do we have any chemists on the board that understand chellation? Would the proper mix of the proper type of mol***es and water work as well? Like I said above, I tried researching chellation and almost immediately confused myself.
    patmanta likes this.
  20. patmanta
    patmanta
    from Woburn, MA
    It would be nice to find a product (other than mol***es) that we could get ONE gallon of and dilute to about 30 gallons of rust juice. I was watching one of those powerblock type shows online last week and they had a big Rubbermaid agricultural tub FILLED with that WD40 rust soak so they could dip their torn down flathead block and heads in it. I think at $28/gal, that money would go VERY far spent elsewhere.
  21. studenut48
    studenut48
    from Hanson, Ky
    I have used both. Evapo is cheaper works just as good. However it's shelf life is not as good as metal rescue. Still i rather have evapo
  22. tubman
    tubman
    Well, I'll come back and answer my own question. After doing the carb base and some Corvette seat belts I am restoring, my gallon of Metal Rescue was all done! It started out quite "watery", and quickly "wore out" (turned black and quit working). It was all done after the carb base and some seat belt buckles. To finish up, I ordered in a gallon of Evaporust from Amazon; about the same cost (with shipping) as the Metal Rescue at Home Depot. As soon as I poured it in the tray I was using to derust the buckles, I could tell the difference. It seemed thicker and more substantial than the the other product. After a days soaking, all the rest of the rust on the buckles was gone. The Evaporust still looks good, and I was tempted to pour it back in the jug (but I didn't).
    In my opinion, the Evaporust worked better and lasted longer than the Metal Rescue. The latter works OK in a pinch, but it's Evaporust for me from now on.
    bchctybob likes this.
  23. mlaurence1029
    mlaurence1029
    Evaporust and Metal Rescue Rust Bath are the same thing. I’ve mixed the two and used both separately.
    Just wanted to say one thing. Someone said that you can just leave metal in it for a week or whatever. DO NOT DO THIS. It will turn the metal black.
    2 hours or less for light rust
    12 hours for moderate
    24+ for heavy
    Check on it every so often. Also, keep it in a sealed container while using/storing, otherwise it will evaporate. And finally, the temperature is IMPORTANT. You need the stuff to be in a 70 degree (f) room/garage. If it is too cold or two hot it will work like ****!
  24. mr.chevrolet
    mr.chevrolet
    I remember seeing at Hershey, some hot girls pushing some Beet Juice rust remover. anyone ever try it. I spent some time talking to them but didn't buy any.
