Is my distributor bad?
Discussion in 'The Hokey Ass Message Board' started by 49 lincoln, Jun 4, 2013.
  1. 49 lincoln
    49 lincoln
    from reno
    I'm swapping my distributor over to a new block and noticed this doesn't look too hot... ImageUploadedByH.A.M.B.1370363917.516383.jpg ImageUploadedByH.A.M.B.1370363930.536251.jpg
    How bad is this? Can I reuse this distributor?
  2. Jokester
    Jokester
    What are your misgivings? I don't see anything critical.
  3. I'm not sure what I'm looking at. Is that a crack or casting flash? It seems fine to me.
  4. Rickybop
    Rickybop
    It'll be fine. That just looks like a casting flaw. The width of the diameter isn't so important as the machined diameter itself...that's what locates the body of the distributor. You might give it a light grinding or filing just to smooth the rough edges, but even that isn't necessary. One thing you wanna check is the condition of the bushings. Check to see if you can wiggle the shaft that goes through the distributor at all. If you can, it could use new bushings. If not, I'd use the dist with no worries.
  5. GrouchySS
    GrouchySS
    I have sean many chevy distributors that looked just like that
  6. Ya, it's just a rough casting. No big deal.
  7. Bruce Lancaster
    Bruce Lancaster
    What's up top? 1949 Lincolns only apparently got a Delco with a real centrifugal/vacuum advance, later ones '50-51. got the wretched Holly Loadamatic.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Nope. I agree its fine just a casting flaw that is superficial.
  9. 49 lincoln
    49 lincoln
    from reno
    Thanks Fellas! I'm Rollin with it!
